Cooling System Flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmah!, Mar 26, 2017.
  1. Mar 26, 2017 at 8:53 PM
    Timmah!
    Timmah! [OP] Well-Known Member
    TIM
    Hey Tacoma Brothers,
    I helped my buddy Sean do a cooling system flush on his rig. His cooling system had some nasty pond scum looking green coolant and he wanted to switch over to Toyota coolant. We made a video of it and here it is:
    <iframe width="560" height="315" src="https://www.youtube.com/embed/oQsxmi-CNng" frameborder="0" allowfullscreen></iframe>
    01GreenTacoma likes this.
  2. Mar 26, 2017 at 9:24 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I just replaced my radiator and flushed the system. Mine was pretty icky as wel!
  3. Feb 16, 2022 at 8:30 AM
    rockinrich
    rockinrich Well-Known Member
    here's a stupid question,if your truck holds 9.5 quarts and you only get 8 quarts out,why can't you get that last 1.5 quarts out?
  4. Feb 16, 2022 at 8:35 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    thing like this, fluid doesn't flow uphill w/o external pressure pushing it up
  5. Feb 16, 2022 at 9:45 AM
    rockinrich
    my truck holds 9.1 quarts,so if i only get out 8 quarts the other 1.1 quart is nothing to worry about?
  6. Feb 16, 2022 at 10:04 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    depends,
    if the old coolant was still good, then don't worry
    if the old fluid was past its time then a few cycles of distilled water then new coolant
  7. Feb 16, 2022 at 10:09 AM
    rockinrich
    it was old so i will do a few cycles of distilled water and let it get up to operating temp and then should i turn the heater on? and for how long ?
  8. Feb 16, 2022 at 10:36 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    till the thermostat open and the water can make a full loop. This vid explains
  9. Feb 16, 2022 at 11:17 AM
    rockinrich
    thank you,i will check that video out.
  10. Feb 16, 2022 at 12:35 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    The way I do it is drain the radiator fill it with distilled water using spill proof funnel. run til thermostat opens drain and repeat until it’s just water coming out. Then then drain and fill with coolant.
  11. Feb 16, 2022 at 3:51 PM
    rockinrich
    Thank you,and i guess you know the thermostat opens if you have heat coming through your vents?
  12. Feb 16, 2022 at 4:05 PM
    e.deCastro
    Eric
    San Diego
    Well the water (coolant) will start moving I just let it get to temperature.
  13. Feb 16, 2022 at 5:11 PM
    rockinrich
    got ya,thanks!
    e.deCastro[QUOTED] likes this.
