Cooling System Maintenance Question
Discussion in 'Technical Chat' started by bkrdave36, Apr 27, 2017.
  1. Apr 27, 2017 at 8:19 AM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Hey All.....
    Its that time.....
    I need to replace my hoses in my cooling system.
    I see two (upper and lower radiator). Are there any hidden ones I dont see?
    Should I replace the thermostat whike I am at it?
    Any other suggestions welcome.
    240k miles on an 06 V6 Doublecab PreRunner.
  2. Apr 27, 2017 at 8:19 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Heater core hoses
    GPsevinSixx likes this.
  3. Apr 27, 2017 at 8:24 AM
    bkrdave36
    Dave
    Wittmann,AZ
    Also which is the best coolant to use?
  4. Apr 27, 2017 at 8:26 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Look here for related parts. Thermostat and rad cap should also be on that list and if you haven't done the water pump. Don't forget to purchase the necessary gaskets for all the hard parts! Check operation of the fan clutch also.
    http://parts.olathetoyota.com/auto-...oling-system-cat/radiator-and-components-scat
    Check your Radiator end tanks for leaks also if it's the original.
    Anything Factory compatible will be fine. I'd stick with the Toyota stuff if you haven't had issues with it.
  5. Apr 28, 2017 at 8:48 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I agree with all the above except the suggestion to replace the water pump. Thats a helluva lot more work. Its usually done when replacing the timing belt.
  6. Apr 30, 2017 at 7:17 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    2nd Gen V6 Tacoma has a Timing Chain.
