Cooling System Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkrdave36, May 25, 2023.
  1. May 25, 2023 at 9:04 AM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Deep dive issue here...
    I was about to go on a vacation starting with Overland Expo in Flagstaff last weekend. Engine overheated while in line at the drive up ATM. Took it to a local shop I've used for years with no problem (not a dealership).
    Replaced the radiator as the mechanic said it was corroded on the bottom and was also partially clogged. It had 150k miles +/- on it.
    Replaced the water pump as the flow rate wasn't where it should be. It also had about 150k miles.
    Replaced the thermostat because why not.
    Thought it was fixed. Yesterday drove it 60 miles one way(freeway and town driving) with no issues. It sat for a couple hours. Then drove it back home the same 60-ish miles with no problems. Until i turned in to my neighborhood and the temp gauge just spiked. Got it home just as the gauge hit vertical. The overflow tank was boiling but no leaks that i coukd find. No codes thrown. Drives fine.
    Driving it back to the shop this morning and temp gauge, so far, is holding steady in the middle.
    WTF!?!
  2. May 25, 2023 at 9:09 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How is the fan clutch?
    A sign of a failing fan clutch is over heating at low speeds and idle.
    BassAckwards likes this.
  3. May 25, 2023 at 9:20 AM
    bkrdave36
    Dave
    Wittmann,AZ
    Mechanic says it's good. It was replaced about a couple years ago.
  4. May 25, 2023 at 9:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Radiator cap? Air bubble in system?
    PzTank likes this.
  5. May 25, 2023 at 9:34 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Quite possibly an air bubble otherwise they may have to check for combustion gases in the cooling system
    TnShooter and SR-71A like this.
  6. May 25, 2023 at 9:36 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Clogging in radiator could mean clogging in water jacket too. Might need more flushing. Were you able to check the flow rate with the new water pump? Might also need a new heater core as shit goes where the water goes.
    12TRDTacoma likes this.
  7. May 25, 2023 at 9:37 AM
    bkrdave36
    Dave
    Wittmann,AZ
    New rad cap. Did a block test, smoke test, pressure test, all negative.
    Engine was rebuilt 150,000 miles ago because I got the trademarked Toyota head gasket leak back then.
  8. May 25, 2023 at 9:39 AM
    bkrdave36
    Dave
    Wittmann,AZ
    They flushed the system and flow rate was substantially better after the new water pump.
    TOMB likes this.
  9. May 25, 2023 at 9:40 AM
    bkrdave36
    Dave
    Wittmann,AZ
    If it was an air bubble, wouldn't the water pump have pushed it out of the system after running for that long?
  10. May 25, 2023 at 9:43 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The new thermostat may be sticking.
    Ceedub53 likes this.
  11. May 25, 2023 at 9:48 AM
    bkrdave36
    Dave
    Wittmann,AZ
    At this point, every new part that was installed is suspect.
    whatstcp and TnShooter like this.
  12. May 25, 2023 at 10:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Burping requires an open system. Usually done with cap off. Sometimes it leaves a void in top of radiator which you can re-top with coolant
    bkrdave36[QUOTED][OP] likes this.
  13. May 25, 2023 at 10:43 AM
    bkrdave36
    Dave
    Wittmann,AZ
    Looks like we are going to give a new fan clutch a try.
    Fingers crossed it works.
    TnShooter likes this.
  14. May 25, 2023 at 10:56 AM
    bkrdave36
    Dave
    Wittmann,AZ
    It was replaced a couple years ago.
  15. May 25, 2023 at 3:06 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Fan clutch didn't work. Still overheating at the lower rpms. Ran fine at highway speeds and 45 zones. Took it up Yarnell hill. It's a 9 mile grade speed limit due to turns between 35-45 mph. 3/4 of the way up the temp gauge starting going up.
    Temp comes back down as engine rpm's increase.
    Sitting at a burger joint waiting for it to cool down so I can check coolant levels.
  16. May 25, 2023 at 3:54 PM
    joba27n
    Nolan
    Alberta
    I'd try backflushing the heater core and/or using an oem thermostat and water pump and water pump gasket if you have an aftermarket one.
  17. May 25, 2023 at 4:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    Try pressure testing the new cap.
    joba27n likes this.
  18. May 25, 2023 at 5:52 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Would the use of a "universal" coolant instead of the pink Toyota rated stuff make this problem?
  19. May 25, 2023 at 6:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Coolant type doesn't really affect temp control.
    At this point I'd be looking at headgaskets.
    You won't always see smoke on Toyota failures, but what typically happens is the odd misfire on cold start, and pegged temps.
    Are there any other symtoms?
  20. May 25, 2023 at 7:45 PM
    bkrdave36
    Dave
    Wittmann,AZ
    About 150k miles ago I had the leaking head gasket. Ended up rebuilding the entire motor.
    At the moment, there are zero codes being thrown, the vehicle runs very well (unlike when the gasket was leaking before), it's just a low rpm over heating issue.
