Cooling system rebuild questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pig Punisher, Feb 24, 2012.
  1. Feb 24, 2012 at 8:00 PM
    Pig Punisher
    Pig Punisher [OP] Well-Known Member
    Dearing ,ga
    07 4x4 sr5, 99 4x4 trd
    Walker Evans coilovers, 285/75/16 km2's, Allpro tube bumper, Warn m8000, custom spare tire carrier, rear bumper work in progress: the 99; tec one coilovers 32" km1's on 17" stock chevy steelies, 1.5" rear shackles
    Just purchased a new aisin water pump, koyo radiator, oem tstat. While I'm in there I'd like to take care of some oil leaks. Oil pan is a must. Gonna use toyota fipg for that. Anyone ever done this? Any tricks to removing the oil pan? What else should I do while I'm at it. The truck is a 2.7 with 160k on the clock.
  2. Feb 24, 2012 at 8:33 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Timing chain on mine looked really good. The guides were barely worn, but the chains stretch over time. It might not be a bad idea to change it. Hoses are also a good idea.
  3. Feb 24, 2012 at 9:05 PM
    Pig Punisher
    Dearing ,ga
    From what I understand you have to pull the head to replace the timing chain on this engine, which I would rather not do. I'll check the fsm though.
    Thanks
  4. Feb 24, 2012 at 9:15 PM
    Tylerm5000
    Tyler
    Oregon
    The cover gasket. may need to be replaced at least. It can leak over time.
  5. Feb 24, 2012 at 9:29 PM
    Pig Punisher
    Dearing ,ga
    Thanks. I'm sure once I get started it will snowball. I just want to do as much as I can while I have the chance.
