Cooling system
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97tacomaTSR, May 12, 2017.
  1. May 12, 2017 at 11:42 AM
    97tacomaTSR
    97tacomaTSR [OP] Member
    Shawn
    1997 Maroon tacoma lx
    None
    MY FIRST TOYOTA, 97 TOYOTA TACOMA LX, HAVING ISSUES BURPING THE TRUCK, I'VE REPLACED RADIATOR, THERMOSTAT, CLUCH FAN, AND CANT SEEM TO ALL THE AIR OUT THE SYSTEM, VERY FRUSTRATING. HELP PLZ
  2. May 12, 2017 at 11:43 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    What have you done so far to "burp" it?
  3. May 12, 2017 at 11:45 AM
    TopDawg1776
    TopDawg1776 Well-Known Member
    Sam
    Nashville
    2022 Tundra TRD Pro
    Hmm, go to autozone and see if they can lease you a camera for looking in engines. Check for clogs, also water pump maybe?
  4. May 12, 2017 at 11:47 AM
    97tacomaTSR
    Shawn
    None
    DRIVER SIDE ON BLOCK, HEATER ON HIGH,
  5. May 12, 2017 at 11:49 AM
    01GreenTacoma
    Might be a dumb question, but do you have the radiator cap off??
  6. May 12, 2017 at 11:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    Park nose up.
    Remove radiator cap.
    Run truck at idle.
    Top up as nessecary.
    It should easily 'self burp' as air has to move through the system when it's pressure free, and the air will rise.
    skeezix and TopDawg1776 like this.
  7. May 12, 2017 at 11:56 AM
    97tacomaTSR
    Shawn
    None
    Do I need to have the heater on?
  8. May 12, 2017 at 11:57 AM
    97tacomaTSR
    Shawn
    None
    How about the a/c?
  9. May 12, 2017 at 11:58 AM
    01GreenTacoma
    I changed my radiator out a few months back and the truck burped itself sitting nose up in less than 10 min. I turned on the heater and let it idle while keeping an eye on the fluid level.
  10. May 12, 2017 at 12:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    I think the heater circulates full time and 'On' is a door position. If I'm wrong, then yes, heater on.
    AC on will help reach operating temp faster if you don't need to run the heater.
  11. May 12, 2017 at 12:16 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Get one of those super funnels, like 20 bucks. It goes on like a radiator cap.put nose up, fill funnel turn on defrost to highest. Hold throttle at 3000 rpms.go til no more bubbles in funnel.put plug in funnel,put on cap and enjoy the day
  12. May 12, 2017 at 12:17 PM
    97tacomaTSR
    Shawn
    None
    While driving, it only seems to hotter when AC IS ON
  13. May 12, 2017 at 5:55 PM
    Glamisman
    Glamisman Well-Known Member
    if it is a 4 cyl the jiggle valve on the T-Stat is at 12 o'clock if it is a V6 the jiggle valve is at 6 o'clock... do you remember which way you installed the T-stat?
  14. May 12, 2017 at 7:40 PM
    97tacomaTSR
    Shawn
    None
    YES SIR, I WAS INFORMED ABOUT THAT, ON THE 2ND ONE THAT REPLACED WITHIN 2 DAYS. THE IDIOT AT THE SHOP I THINK PUT FAN ON BACKWARDS, FLAT SIDE OF THE FAN IS FACING THE MOTOR.... IS THAT THE RIGHT WAY, IM SEEING PICTURES THE OTHER WAY. ?
  15. May 12, 2017 at 7:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think your caps lock button may need attention? Maybe some keyboard lube will keep it from sticking on? :p
  16. May 12, 2017 at 8:00 PM
    97tacomaTSR
    Shawn
    None
    Sorry, Done:)
    Dalandser likes this.
