Cooper Discover AT 4S 65 to 70's
Discussion in 'Wheels & Tires' started by kenacp, Jul 28, 2020.
  1. Jul 28, 2020 at 9:50 AM
    kenacp
    kenacp [OP] New Member
    Have a 2017 Sport with factory Toyo Open Country 30's. Going to replace with Cooper AT 4S. Pros and cons of going from 265/65/17 to 265/70/17. Seems like I saw a post on it, but can't find it now. The Cooper specks seem to say they will work on the same rims.
    Thanks
  2. Jul 28, 2020 at 9:57 AM
    Tacospike
    Two Trucks
  3. Jul 28, 2020 at 9:57 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Occasionally people have experienced rub on their mudflaps, but that seems to be rare with stock wheels. I think the bigger tire will actually correct your speedometer. Mine is slightly slow reading. It will make the truck push a slightly harder gear effectively. These trucks don't need that at all but I'm not sure what difference one inch of tire size will make in reality. I plan to try it when I wear mine out. I'm interested in first hand experience to see if the gear ratio is noticable
