Cooper Discoverer A/T3 megathread?
Discussion in 'Wheels & Tires' started by callmeammo, Apr 26, 2018.
  1. Oct 2, 2018 at 11:16 AM
    #441
    marc222
    marc222 New Member
    1997 Toyota Landcruiser
    stock
    Tire diameter:
    To accurately measure tire diameter it is best to wrap a tape measure around the circumference of the tire at centerline, then divide this result by Pi to get diameter (circumference / 3.14). If you try to measure diameter of a tire while on the truck, the weight of the truck deflects the tire about the inch or so you are missing, and the shoulder diameter of a tire is slightly less than the centerline diameter (diameter is stated at centerline and mounted and inflated).
    Also SUV and regular standard load car tires (sometimes called P-Metric) are measured at 26 psi, most Light Truck LRC at 50 psi, and most LRE at 80 psi. A LRC tire at 32 psi will have slightly less diameter than it will at 50 psi...
    Tire width:
    Stated tire width is measured at the maximum section width, not tread width... This is how a 265/75R16 and a 265/70R16 both have a nominal width of 265 mm... Typically the lower aspect ratio tire will have a wider tread width... In this case the 265/70 tread is a wider than the 265/75 tread width.
    Stamped max load of an SUV tire compared to same size light truck (LT) tire:
    Passenger and SUV tires use a different load equation than Light Truck (LT type) tires; the Light Truck load equation is more conservative since it assumes carrying a high near max load all of the time (higher duty cycle) and assumes higher un-sprung mass/weight of heavier axle and suspension components that pound the tire over pot holes and such. Also an SUV tire when used on a "1/2 ton truck" or in more of a work truck service its stamped max load is reduced by 10% (calculated by max stamped load divided by 1.1).
    LT LRE type tires have stronger belts and ply than their SUV brothers even though the sidewall often reads "2 ply poly, 2 steel, 1 nylon"... the actual strength and often thickness and/or cords per inch are higher for the LT type tire, since LT LRE type tires need that strength for 80 psi service on 1 ton type trucks that are anticipated to always be working, always carrying a heavy load. LT LRC is very often the good mid-point for tire structure flexibility for ride quality and some boosted strength to resist off road bruising and snags and punctures. That being said, LRE tires do work well on lighter Toyota trucks at a more suitable on road on highway 30 to 36 psi or so depending on loading and such (the chalk method is good). Many times the LRC option is not available leaving only the LRE option (many manufactures skip LRD in the small to middle sizes, many only offer a LRD in 305 and wider tires).
    SUV type tires tend to be tougher than passenger tires but not quite to the Light Truck level which tends to give the SUV tire a smoother ride, slightly better fuel economy, but can be more susceptible to off road sidewall bruising and such... If lots and lots of off-roading with ruts with tree roots and larger rocks are involved then the Light Truck tire option makes sense. Also Light Truck tires tend to have deeper tread depth than SUV tire so they could wear longer per set of tires.
    Gmetaco, Mtn Mike and ToyoDrew like this.
  2. Oct 2, 2018 at 11:43 AM
    #442
    blueyceman
    blueyceman Member
    Andy
    2018 Tacoma Cement DCLB TRD Offroad
    Marc - thanks. That makes sense to me and I knew there had to be a good explanation out there!
    marc222[QUOTED] likes this.
  3. Oct 2, 2018 at 12:56 PM
    #443
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for sharing! The new sidewall design/s look awesome!
  4. Oct 2, 2018 at 4:01 PM
    #444
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    For those with load range C's, what are you running for tire pressure? Any chalk tests?
    I've not had time to refine mine yet. Had them inflated to 34psi as that was good for my previous Toyos (also LRC). Ride seems good at that pressure.
  5. Oct 3, 2018 at 7:00 AM
    #445
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    I believe that’s the old AT3, not the AT3 4S.
  6. Oct 3, 2018 at 9:15 AM
    #446
    SpeySquatch
    2016 TRD OR DCSB
    All of the at3 models are light compared to beefier all terrains
    Thegenerik1[QUOTED] likes this.
  7. Oct 3, 2018 at 10:28 AM
    #447
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I have to disagree my AT3 XLT’s are beefy as shit and heavy as shit
  8. Oct 3, 2018 at 10:32 AM
    #448
    SpeySquatch
    2016 TRD OR DCSB
    Well width is an attribute to weight.
    The 32” 255’s I’m putting on 17” wheels are 39lbs. The Falken AT3’s I’m running in 265/75/16 are 51lbs
  9. Oct 3, 2018 at 1:40 PM
    #449
    SpeySquatch
    2016 TRD OR DCSB
    My bad. Excluding XLTs because they are their own beast of a tire. They aren’t even available in most standard sizing. I meant the standard AT3’s
    Matmo215[QUOTED] likes this.
  10. Oct 5, 2018 at 8:33 PM
    #450
    HeyMrCarter
    HeyMrCarter Well-Known Member
    Just put on a set of Cooper At3 4s tires in 265/75r16. Look and ride great so far. Taking them off road next weekend. Also got another TRD pro wheel/tire for the spare.F41D0E91-8C35-460D-81D4-4A4AEDC13733.jpg 7B1283CB-7B36-47E0-B15C-66CF559BB731.jpg
    ryanbitt and toyotatacomaTRD like this.
  11. Oct 6, 2018 at 10:16 AM
    #451
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    That looks great! How much did they charge you for the sensors? I have one that just went out
  12. Oct 6, 2018 at 11:08 PM
    #452
    kdtpnw
    kdtpnw Active Member
    2011 6spd TRD Off Road Access Cab
    Thanks, yeah I’m definitely happy with them. They charged me $35 each for the sensors, said retail was $60. Since I was already getting tires installed there was no extra labor, not sure what it is if you need to get one swapped out on an existing tire. He did scan all of mine and said two were out and two were at 10% - so if you have one out, the others probably aren’t far behind. Might make sense to have them all done, especially if you can get someone to give you a deal on four. I’d definitely recommend checking out discount tire, was impressed with their service.
  13. Oct 8, 2018 at 6:23 AM
    #453
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    This will probably be my next tire/size. Any chance you could post additional pictures of your rig with these tires mounted? Thank you.
    ryanbitt likes this.
  14. Oct 9, 2018 at 9:24 PM
    #454
    MattEcho
    MattEcho Optimist
    CO
    2017 Silver Tacoma TRDOR DCSB AT (non-JBL Tech)
    Frustrating, I was all set to pull the trigger on the at3 4s’s over the weekend. They were $133/tire at local DT and $160 at DTD. But I was waiting for my new wheels to come in. Wheels shipped today, so I look at tires again, figure I’ll go ahead and buy. Tires are now $160 at DT and not even available at DTD. Had no idea prices fluctuated like that...
  15. Oct 9, 2018 at 9:46 PM
    #455
    kdtpnw
    See if they’ll price match. Mine did, no questions asked. I found the deal online and submitted it on their website, local Discount Tire store called me the next morning.
  16. Oct 14, 2018 at 12:35 AM
    #456
    Teksou
    Teksou Well-Known Member
    Northern, CA
    2015 TRD Off Road
    Here’s my AT3 XLT in 315/70/17 that I installed last weekend. 87CA0A91-7D9A-4AD7-8A9B-2ECCE427E468.jpg 0EFF390C-869B-4E0D-A596-99BC64E2DF12.jpg 40939675-B3F7-4690-993B-8025246C4601.jpg
  17. Oct 14, 2018 at 12:52 AM
    #457
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    Those XLT are fire!! Just wish they had more sizes available and weren't so heavy (E-Load for all the 17" wheel options).
    Lord Helmet and Teksou like this.
  18. Oct 14, 2018 at 8:45 AM
    #458
    TheKar
    TheKar New Member
    Karl
    2013 Tacoma TRD LB
    Thats a cool rig Teksou!
    Max tire size question....What's the biggest tire I can run on a 13 Quad 4x4 LB without a lift ?
    Teksou likes this.
  19. Oct 14, 2018 at 8:55 AM
    #459
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Cab size doesn’t matter as it doesn’t change anything to do with tires/wheels. Without more info we have no idea what size tire you can fit. Wheels/offset, lift, cmc, pinch welds best??? Tell us what you have.
  20. Oct 14, 2018 at 9:20 AM
    #460
    TheKar
    TheKar New Member
    Karl
    2013 Tacoma TRD LB
    Ya sorry...forgot to add the word STOCK. So no lift like I said and wheels are 16. I still have the mud guards on, but I can remove those. I think I found my answer though...265/75/16 is that correct? Looking at BFG AT & Cooper Discoverer stt pro
    Thanks for the help Erik
    Thegenerik1 likes this.
