Cooper Discoverer A/T3 megathread?
Discussion in 'Wheels & Tires' started by callmeammo, Apr 26, 2018.
  1. May 14, 2020 at 11:34 AM
    #1381
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    Yes they are the same as the original A/T 3 they just dont have the lastets compound and tread updates that the AT3 4S and XLT have
    maverick4x2 likes this.
  2. May 14, 2020 at 11:50 AM
    #1382
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    Apparently 235/70r17 is an unusual size...lol. Found exactly one offering, thanks for the help
  3. May 14, 2020 at 1:35 PM
    #1383
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Does anybody have a lot of miles on a set of the AT3 4S? Just curious how they’re holding up at higher mileages?
    Philrab likes this.
  4. May 15, 2020 at 6:29 AM
    #1384
    Rankin
    Rankin Well-Known Member
    Scott
    2015 MGM Tacoma SR5 DCLB 4x4
    None yet
    Wanting to know if anyone is running 265/75 16 on their Gen 2 Tacoma with factory mudflaps still attached, any rubbing?
  5. May 15, 2020 at 2:47 PM
    #1385
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I have almost 50k on my 4S's, and nearly 2 years of owning them as I bought them just as they came out in 2018. Still measuring somewhere around 9/32nds with plenty of blocky tread left. Maybe slightly noisier after 45k or so but still quieter than my stock tires were at 25k when I replaced them with the 4S's. Still handle corners superbly and stick to wet pavement super well. Literally the best tires I've ever owned as a solid all-around tire that wears slowly and performs well. Will easily get 60-70k out of them if I want to and I'm kind of hard on tires driving a lot in the Appalachian region. Even with tread left, I generally end up swapping them by 30-40k due to degradation in handling performance. Not so with these.
  6. May 15, 2020 at 5:36 PM
    #1386
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Mine came off on a trail, but I think it would be pretty close. Most people report rubbing. I even pulled off the little spats from the front bumper that hang in front of the wheels cause those looked close too.
    That’s encouraging. Just got mine on but came from stock Dunlop 245’s to these and wet traction is noticeably improved. Used to, I could break the tires loose in the wet on command. Now, the truck just grips and goes.
  7. May 15, 2020 at 5:38 PM
    #1387
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    That’s great! Do they throw rocks bad? I’m thinking the 4S would be perfect on my moms 5th gen 4Runner in 265/70/17 (stock size).
  8. May 17, 2020 at 4:27 AM
    #1388
    bshammer0
    Brandon
    Nashville, TN
    Brand new they would hold onto a few small pebbles until you got up to speed on the highway, but as they’ve worn they aren’t catching many rocks anymore. It’s not terrible by any means but that’s probably the only imperfect thing about these tires and even this is minor
    07 sport 4x4[QUOTED] likes this.
  9. May 20, 2020 at 1:38 PM
    #1389
    Supernaut
    Supernaut Member
    2014 Black Tacoma TRD
    I apologize if this has been asked. I got my 265/75R16s installed and now the TPMS light is on.
    My question is, do you all run them at the Toyota recommended pressures or something else and i shouldn't have gotten new sensors?
    At the moment, I'm not towing anything and for the most part, the truck (2014) is used on the road.
  10. May 20, 2020 at 5:24 PM
    #1390
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    The shop probably broke one of your sensors unless you are running super low pressures.
    Philrab likes this.
  11. May 20, 2020 at 6:17 PM
    #1391
    Philrab
    Phil
    Either your spare just happened to start running low at the exact time this got done, or they busted one of your sensors. Take it back to them.
  12. May 23, 2020 at 12:28 PM
    #1392
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Yes. Wheels are FN Offroad Countersteer's 16x8 0 offset/4.5" back spacing with 5100 stock offroad springs at third notch up but they have settle to where I may only be seeing 1-1 1/4" of lift. Have ran them with front mud flaps off but was tired of my doors and side windows covered with road spray. Have not had any rubbing.
  13. May 26, 2020 at 12:00 PM
    #1393
    Toysareus
    Toysareus Member Passed Away—2021
    USA
    Installed Cooper Discoverer AT3 LT (load range C) LT265/75-16 date code 0120. Tires have 3 peak snowflake symbol. No rubbing anywhere, plenty of clearance. Tires are quiet on highway, Prinsu rack makes more wind noise.
  14. May 26, 2020 at 12:34 PM
    #1394
    Toysareus
    USA
    Just installed—-no rubbing, plenty of room. Tires are the LT ones using 3rd gen OR wheels. See my post in this section.
    Edit: I do have 5100s all around with front set @ .85–which increases my height 1”. As you can see from pic, that wouldn’t matter.
  15. Jun 5, 2020 at 3:28 PM
    #1395
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    on my 2011 AC, chalk test came out to about 28psi.
    No TPMS isues
  16. Jun 11, 2020 at 7:19 PM
    #1396
    DVS4.0
    DVS4.0 Well-Known Member
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Toytec coils, Bilstein 5100's, Freedom Offroad UCA, Pro Comps Wheels, Spidertrax, 33's, Memphis Audio
    Love these tires and they are so quiet on the road. The step up to 285's killed my MPG but that's the cost for the looking good.
    boostedka and Brownie_Man like this.
  17. Jun 12, 2020 at 6:10 AM
    #1397
    sprjr
    sprjr @tacqito on IG
    Stephen
    Florida
    2018 Black Tacoma SR5
    ✅Tepui Tent + Relentless Bed Rack ✅Discoverer A/T + AR Black Wheels ✅SSO LoPro Bumper + Smittybilt X20 Winch ✅Dash MultiMount + Glovebox Organizer ✅Window Tint ✅TacoVinyl Raptor Grille + Smoked Lights ✅Decked Bed Storage System ✅TacomaBeast LED Head & Taillights ✅Black on Black on Black
    How bad was it? I’m about to make the jump as well.
    DVS4.0[QUOTED] likes this.
  18. Jun 12, 2020 at 6:24 AM
    #1398
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Making me feel bad for never shining up my tires. Looking good!
  19. Jun 12, 2020 at 10:59 AM
    #1399
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Loss of about 2mpg. I would average 20-21 at 65mph went down to 18-18.5mpg. I use a scan guage for consistency.
    Road_Warrior and sprjr[QUOTED] like this.
  20. Jun 12, 2020 at 12:19 PM
    #1400
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Looks sharp! The Pro Comp Series 29 looks really good in 16-inch.
