Cooper Discoverer A/T3, The Ranger's Review
Discussion in 'Wheels & Tires' started by Maticuno, Feb 22, 2016.
  1. Nov 23, 2016 at 9:26 AM
    #61
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    While it would be nice it doesn't hinder performance. Remember performance > aesthetics.... I would do the Coopers.
    Tyler
    Maticuno[OP] likes this.
  2. Nov 24, 2016 at 8:27 PM
    #62
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I'll try to get pictures this weekend. I would go for the C Load Coopers over the Grabbers.
    Bloodhound[QUOTED] likes this.
  3. Nov 25, 2016 at 5:25 AM
    #63
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I had these on my Tacoma and I have to say they were some of the worst tires I have ever had. Tread wear was horrible and once they started getting excessive wear they were absolutely dangerous on wet roads.
  4. Nov 25, 2016 at 5:30 AM
    #64
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I have the Pep Boys model "Adventurer A/T." So far so good after 14 months.
    Day of install:
    slamson00 and markelhof like this.
  5. Nov 28, 2016 at 4:35 PM
    #65
    Maticuno
    2011 Suburban 2500
    OP updated with photos for the 15k mile review.
    Bloodhound likes this.
  6. Dec 1, 2016 at 12:35 PM
    #66
    jgang
    jgang Well-Known Member
    Load Range C. More versatility. Drop the PSI to 32 front/30 rear unloaded and the around town ride is quite nominal. Go to 36/34 for highway cruising or moderate loads. Go higher if needed for heavy loads or towing. Drop down to anywhere between 20 and 30 for snow, sand, moderate crawling or whatever floats your boat. Always stable and true in every situation. No, not as soft as a P-series, but hey, it is, after all, a truck and one that benefits from proper shoes. I'm on my second set of 275/70-17s and they're amazing. No, they don't have the aggressive look of a KO2 or Duratrac, but they cover about 98% of the situations I would ever come across.....and I get a loooooong way from nowhere on occasion. Yes, they are more puncture resistant too, no doubt about it. Like I said previously, this is a "fire and forget" tire that just about does it all and very well at that. I really can't imagine a more versatile tire for the vast, vast bulk of Tacoma owners.
    dre5491 and TerraCanadensis like this.
  7. Dec 1, 2016 at 12:48 PM
    #67
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've had P265/75/16's on my truck for almost 3 years and 48,000 miles. Nothing I can add, they simply work. If I were the type to drive them down to the legal minimum I might get close to 60,000 out of them. I wrote the check for $550, got an $80 rebate. Just bought another set for my F-150 and expect the $70 rebate any day. I had them on a Wrangler too.
    The P series tires are rated to haul MORE than C rated LT's and exactly the same as D rated tires. Anything that will puncture the tread on a P series will puncture the tread on a C or D rated tire. The LT's have a tougher sidewall. If you drive a lot in large loose rock with low air pressure the P's are more likely to get the sidewall cut.
  8. Dec 6, 2016 at 6:54 PM
    #68
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I ended up with P285/70/17's. What PSI are y'all running at?
  9. Mar 30, 2017 at 5:07 AM
    #69
    bhughesru03
    bhughesru03 Well-Known Member
    Virginia
    20 TRD OR 4x4 MGM
    After about 32k miles, it's almost time to replace my at20's. After reading this post and a few others I decided to go with the Cooper AT3 265 70 r17 for my stock '15 Sport.
    I drive mostly highway on cruise control. What would be the best psi to run for the P series?
  10. Mar 30, 2017 at 11:19 AM
    #70
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Start out around 36fr & 34rr and adjust from there.
  11. Mar 30, 2017 at 12:15 PM
    #71
    bhughesru03
    Virginia
    20 TRD OR 4x4 MGM
    Thanks, I will. Sorry for being a newbie, but what should I look for to know I need to adjust the psi up or down?
  12. Mar 30, 2017 at 8:29 PM
    #72
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    think you've finally convinced me that these (in C-load) will be my next tires.
  13. Apr 2, 2017 at 6:24 PM
    #73
    McNice
    McNice Well-Known Member
    Ken
    2006 Access Cab 5sp... the small motor.
    Just got some 265 AT3's put on my 06 for 170 per tire, plus a 75(i think) mail in rebate. Been 4 or so days and as of right now I am very happy with them. They seemed to be the best option for me, driving 22 miles each way to work, and occasionally adventuring into the woods. Can't vouch for how well they preform off road, but on road, thus far they have been excellent. Very quiet and very smooth. Was HOPING that the pulsating vibration at 70 mph would go away with fresh rubber and balance, but it's still there. Regardless that's not the tires fault apparently. All I can figure at this point is re balance the drive shaft? [​IMG]
  14. Jun 24, 2017 at 9:01 PM
    #74
    Maticuno
    2011 Suburban 2500
    OP updated with 30k review.
  15. Jun 29, 2017 at 7:43 AM
    #75
    omegaman1955
    omegaman1955 Well-Known Member
    Henry
    Somewhere near Pie Town/Quemado,NM
    '98 Tacoma 4x4 SR5
    Good luck with the P rating if you come to NM. Only using E's now myself.
    Love the Coopers but pricey here.Most ranchers/outfitters I know use them on Tacomas,sheriffs/G&F are running them in E's or going with a kevlar type.
  16. Jun 29, 2017 at 10:03 AM
    #76
    Maticuno
    2011 Suburban 2500
    "P-metric tires used on passenger cars and station wagons are rated to carry 100% of the load indicated on the tire's sidewall (or listed for the tire in industry load/inflation charts). However, if the same P-metric tires are used on light trucks, (pickup trucks and sport utility vehicles for example), their carrying capacity is reduced to 91% of the load indicated on the tire's sidewall."
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=195
  17. Jun 29, 2017 at 8:47 PM
    #77
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    S20170629_211216.jpg so i got my coopers at'3 on the E rated load are this good for 99% highway driver some regular loading and not off road . Got the tires for a good deal ( i know a friend deal ) but didn't know on the load range. Any of you have this on E Rated for daily driver ? Or should i sell them and get a different load range .
    Any help would be helpful
  18. Jun 30, 2017 at 9:19 AM
    #78
    Maticuno
    2011 Suburban 2500
    You'll be fine with the E, it'll just ride a bit stiffer. You may have to run slightly lower than normal tire pressure.
  19. Jun 30, 2017 at 9:27 AM
    #79
    taco03Trd
    Carlos
    Riverside ca
    What psi should i run them for freeway all week
  20. Jul 1, 2017 at 9:28 PM
    #80
    Maticuno
    2011 Suburban 2500
    A chalk test will give you the best idea, but to start with I'd go 32 front and 28 rear
