Cooper Discoverer A/T3 vs. Hankook Dynapro AT/M vs. Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by kolache king, Oct 1, 2016.
  1. Oct 1, 2016 at 12:13 PM
    kolache king
    kolache king [OP] Well-Known Member
    Traveling via Louisiana
    2016 Barcelona Red DCSB SR5 4x4
    These are the 3 I've broken it down to. Going with LT265/75/16. It seems the Cooper comes in at 46lbs, Dynapro at 50lbs and Wildpeak at 55lbs. I lean towards the lighter side of things due to keeping the best gas mileage. Current stock firestone is 31lbs I believe. I ran 2 sets of Dynapros on my old F-150 and those bastards were near bullet proof. Got 60k+ out of both sets.
    Anyone have experience with multiple of these?
    Thanks for any help.
  2. Oct 2, 2016 at 6:51 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    The coopers are good, but the set on my wife's Highlander have gotten loud as hell, and have been rotated regularly.. hell they make more noise than my Cooper ST MAxx tyres. So I'm kinda on the fence with them, I had a set on my taco and they were great, but wife's telling me they are starting to slide on her, in wet conditions? Not sure if they're bad set or what? Been thinking of getting a different brand now that they've gotten so loud... I say go with the hakooks it's a gamble on the coopers IMO ? Some are good and some suck...
  3. Oct 2, 2016 at 7:08 PM
    kolache king
    Good info. That huge thread on the Falkens has me curious about those too, but 55 pounds per tire is heavy as hell.
  4. Oct 2, 2016 at 7:11 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I have 47,000 miles on my A/t3's and should get at least 5-10K more. Mine are P265/75/16's, I see no reason to pay for LT's on a truck this light. Mine have been as good as anything traction wise in mud, snow, ice, wet or dry pavement. When new they were very quiet and rode very well. But at this point they are louder and since about 20,000 miles have needed to be balanced with each rotation. They aren't loud, just not as quiet as when new. And the ride isn't bad, just not as good as I like. But for the price it is hard to complain. Cooper was running an $80 rebate when I bought mine 3 years ago. I wrote the check for $550 and have $470 in them after the rebate.
    I'm on the fence, but may consider something else next time. My brother has had good luck with Firestone Destination AT's. Cooper AT/3's run about the same price if they aren't running a rebate which is quite often.
  5. Oct 3, 2016 at 5:56 AM
    kolache king
    Balanced with each rotation? Yikes. I never once had to rebalance those Hankooks on my old truck.
  6. Oct 3, 2016 at 10:01 AM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    The 55lb 265/75/16 Falken is for the E load tire, the standard load is only 44lb.
  7. Oct 3, 2016 at 10:06 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    My C-rated AT3s ride noticeably better than the P-rated Dynapro ATMs I had prior. I'd give them an equal grade as far a traction goes.
  8. Oct 3, 2016 at 10:13 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    That's shocking to me; the P rated Dynapro was the smoothest AT I've ever run. Quiet and not once in their life, 70k miles, did they need a rebalance.
  9. Oct 3, 2016 at 10:17 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Honestly I was a little shocked as well, especially bumping up to an LT tire. The AT3s just seem to soak up little imperfections in the road better.
  10. Oct 3, 2016 at 6:56 PM
    Mace587
    Mace587 Well-Known Member
    North Carolina
    2016 DCSB TRD OR 4x4
    I put the Wildpeaks on today, 265/75/16 standard load on stock setup. Initial impressions are very good. I haven't had a ton of time on them yet, but on my usual drive home from work I was about .7 mpgs lower than what I usually see, which is probably due to the size more than the weight.
    I will say that they look MUCH better in person than in pictures.
  11. Oct 18, 2016 at 8:03 PM
    hksjza70
    hksjza70 Well-Known Member
    Westminster, CO
    Coop finally put weights on their site
  12. Oct 19, 2016 at 4:37 AM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
    I'm curious as to whether those numbers are accurate - they show the E rated 245/75r/16 as weighing only 43 lbs versus 42 lbs for the load range C rated A/T3. That would make the A/T3 the lightest E load range tire that you can buy .
  13. Oct 19, 2016 at 6:52 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I have 45,000mi on Cooper AT3`s, still have half the thread left, at least!!!
  14. Oct 19, 2016 at 6:59 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I've been super pleased with my AT3s plus you cannot beat the Discount Tire Direct EBay deal $170 off Coopers right now. I bought mine when they did the deal in the Spring. You can get P265/75/16 for under $400 bucks shipped to your door until Oct 31.
    Its posted in the deals & coupon section.
  15. Oct 19, 2016 at 6:59 PM
    joetart
    joetart Active Member
    2016 TRD OR
  16. Oct 19, 2016 at 7:02 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I got a set of Method Wheels and 4 AT3 tires from Americas Tire for $1530
    Simon's Mom[QUOTED] likes this.
  17. Dec 6, 2016 at 2:13 PM
    larrybbaker
    larrybbaker Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    Just drove home on a set of Wild Peak A/T3W 256/70/17. Cold and rainy drive home - quiet, great traction - maybe I can dump some sand from the bed :) OTD for $608. Hard to beat.
