Cooper Discoverer AT3 4S Review
Discussion in 'Wheels & Tires' started by bshammer0, Jul 9, 2018.
  1. Sep 14, 2020 at 8:10 AM
    #381
    zpcrowson42
    zpcrowson42 Well-Known Member
    17 TACO SR
    TRD Grille, LEDs, MB Wheels, Discoverer AT3 4S 265/75/R16
    I know this will be a dumb question, BUT..
    My dad and I both currently have 245 on our Tacomas and I noticed recently mine is LT245 and his is P245 and mine are significantly wider than his. I'm assuming the AT3 4S is rated as an LT but I was hoping someone could confirm. I always thought 245 was 245 no matter what until I noticed this.
  2. Sep 14, 2020 at 8:43 AM
    #382
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    The AT3 4S are P rated only.
    Technically you're right, 245mm width is 245mm width no matter which way you slice it. There might be some variability from manufacturer to manufacturer or from tire to tire but it should be close even if they are different flavors.
    Sounds like you have two different sets of tires. If they were both the same type it'd be worth checking to see if you're at the same pressure but I don't think that'll apply here.
    edit: update with a technicality on P-rated......P rated can be Standard Load / Extra Load / Light Load and it looks like the AT3 4S come in both Standard and Extra load
    from Cooper's website:
    and here's some reading on TireRack in case anybody wants it:
    https://www.tirerack.com/tires/tiretech/techpage.jsp?gclid=Cj0KCQjwqfz6BRD8ARIsAIXQCf1QEdsf0phG1pdnoLPTZy_SE51BwYm9ToE5t3fWY4QAI_d-MvVYfHIaAmkrEALw_wcB&techid=55&ef_id=Cj0KCQjwqfz6BRD8ARIsAIXQCf1QEdsf0phG1pdnoLPTZy_SE51BwYm9ToE5t3fWY4QAI_d-MvVYfHIaAmkrEALw_wcB:G:s&s_kwcid=AL!3756!3!354820920374!b!!g!!+load +range&gclsrc=aw.ds
    Learn something new every day. I'd still be they should be pretty close if you've both got the AT3 4S even if they are different load ranges both within the P-load category. Might be worth that pressure check.
    zpcrowson42[QUOTED] likes this.
  3. Sep 14, 2020 at 9:17 AM
    #383
    zpcrowson42
    17 TACO SR
    Awesome! Thanks for the info. I didn't even think about the possibility of different pressure levels but I wouldn't think they would be too far off? We are running two different brand of tires as well. I just noticed it one day when they were parked side by side and pulled out the ol' tape measure for a rough check and mine were a good inch wider.
    I'm wanting to go up to 265 when I order a set so was just curious if there would be any variables to consider.
    doublethebass[QUOTED] likes this.
  4. Sep 14, 2020 at 9:20 AM
    #384
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Since they’re different brand tires I’ll be they’re both nominal 245 but one comes in on the narrow side of acceptable and the other comes in wide. There’s your inch.
  5. Sep 15, 2020 at 12:05 PM
    #385
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    So 245 width is for the furthest part of the tire which is usualy the sidewall area. Tread width of the tire can go almost out to this width or be much narrower. There are also Standards ranges that all tire companies have to follow so you have a range of tread width and sidewall width (section wides) than can affect the look of the tire.
    doublethebass likes this.
  6. Oct 12, 2020 at 4:08 PM
    #386
    zpcrowson42
    17 TACO SR
    168324CB-1844-4559-9DC1-109C7E3C8A50.jpg 4B639BB2-61FE-4967-BF5D-AD5B4B556ACD.jpg 09F1997E-2352-4419-8823-292667D0C5B3.jpg Got mine put on about a week ago! 265/75R16. Loving them so far.
    9mmMike, RobEd, 6MTPro and 3 others like this.
  7. Oct 12, 2020 at 10:06 PM
    #387
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Had mine in the stock size for 1 1/2 years and 30000 miles. Down to 3 /32 of tread. Had 3 flat repairs in that time and never been off road. They seem to be a littel prone to flats. They run a little small in the stock 265 70 16 size at 30.4". Decent tires and decent price. I usually never get more than 35000 miles out of a set of tires.
  8. Oct 13, 2020 at 7:36 AM
    #388
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Interesting. I'm normally very hard on tires and had more tread than that when I traded up to a new set of the same, and I did have them offroad - not a lot but enough to have them on sharp rocks and ledges. Never a flat on either set and I too rarely get more than 30-35k out of a set until these... Keep us posted on what you replace with!
  9. Oct 13, 2020 at 10:21 PM
    #389
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I have a set of falken wildpeaks sitting in the garage 1 size bigger. Was considering getting another set of Coopers or Toyo all terrains as well.
  10. Dec 23, 2020 at 5:13 PM
    #390
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Just got a set of these installed in stock size. I was leaning towards a 10 ply like the grabber atx or st maxx but the tire guy talked me out of it and recommend these. So far I'm impressed, glad I went this direction. If anything they look smaller than my stock tires, but it might be an illusion since I switched to the Baja rims at the same time. Thanks for this thread though, it played a big part in my decision.
  11. Dec 23, 2020 at 9:43 PM
    #391
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    They do run small in the stock size. I had a s set on mine. 30.4" diameter vs 30.6" stock Tires. Good tires though.
    bshammer0[OP] likes this.
  12. Feb 22, 2021 at 8:05 PM
    #392
    bshammer0
    Brandon
    Nashville, TN
    I have to say, I've only been in relatively light snow since I started running these tires over the last 2+ years. Living in Tennessee, we don't often get bad winter weather - but like much of the south, we were pummeled by sheets of sleet, freezing rain, ice and several inches of snow last week. Only the main highways were plowed, leaving all secondary streets packed and ice-covered. These tires performed - their control on icy roads were even remarkable and of course they were solid all around on loose and packed snow as you'd expect.
    Yet another win for the Coopers. ...now hopefully them being bought out won't immediately affect the quality or ~$600/set price tag on these excellent all around tires!!
    doublethebass and RedWings44 like this.
  13. Feb 22, 2021 at 8:09 PM
    #393
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    These things have been as close to winter tires as I've gotten. Tire Rack did some tests with them too and they were the closest to the winter tires in terms of performance of the 4 they had tested together too (I forget what they compared them to).
    From what I can read they're making it seem more like the two companies are getting benefits from the other and are going to remain separate names.
    bshammer0[QUOTED][OP] likes this.
  14. Feb 23, 2021 at 5:32 AM
    #394
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    RIP Cooper Tires
    Starman2112 and bshammer0[OP] like this.
  15. Feb 23, 2021 at 8:11 AM
    #395
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I don't believe Goodyear would end the brand Cooper. I would imagine most people won't see any impact or at least for some time. Most likely the biggest changes will be made at a corporate and the manufacturing level.
  16. Feb 23, 2021 at 8:50 AM
    #396
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Yeah I mean if they modify the manufacturing process and cheap out on the tires or have the production done overseas? It's the end of Cooper tires as we know it or maybe they just won't mess with it. Don't think they'll mess with the branding
  17. Feb 23, 2021 at 1:00 PM
    #397
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Yup was planning on getting a set of Discoverer AT3 4S once the Toyo Open Country R/T's I have wore out but they will at least run me through the rest of the year. Even though it might be a waste of money I'm debating doing a swap out early so I can make sure I get current batches and quality standards.
  18. Feb 23, 2021 at 1:05 PM
    #398
    6MTPro
    HI -> CA
    This looks really good although not as aggressive looking as other options I think this is top of my list of my next tire. Love the look of my Toyo Open Country R/Ts but they are starting to get loud and since 95% of my driving is commuting on highways need a tire that suites both on a offroad needs. Out of curiosity what did you have before and how are you liking the new tires so far?
  19. Feb 24, 2021 at 6:41 AM
    #399
    zpcrowson42
    17 TACO SR
    Yeah, I wanted to go with something that looked more aggressive than stock but still comfortable since I'm on the highway everyday. I had to have them rebalanced after the initial mount but after that, everything has been great so far. I have an SR so I upsized from the stock Nexen 245/75/16 to these. I don't have any roar or vibrating that you would get from a dedicated off-road tire though. I don't what kind of off-roading you do but I have enjoyed them so far and would recommend them as a good daily commute/weekend adventure kind of tire.
    6MTPro[QUOTED] likes this.
  20. Feb 24, 2021 at 7:20 AM
    #400
    6MTPro
    HI -> CA
    Good feedback thanks. I dont do any crazy offroading more like weekend warrior stuff with fire roads and moderate trails, nothing like rock climbing or anything crazy. Like I said too most of my driving is on highway so trying to be realistic with what I need it for. Its the same reason I decided not to go with 285/75/16, although it looks great its going to really cut into the mpg. My commute to work is 36 miles each way. Was tempted to go C rated for the AT3 but I think I like the snow rating and the lighter weight of the 4S better. My short list is the. Cooper AT3 4S, Toyo Open Country ATIII, and possibly the Goodyear Ultraterrains from Americas Tire. Have K02 on our Yukon but they are heavy and not as big a fan on wildpeaks as some other people on here.
