Cooper S/T MAXX vs. M/T ATZ P3
Discussion in 'Wheels & Tires' started by Hilborn, Oct 3, 2017.
Need help choosing between tires.
  1. Cooper S/T Maxx
    77.8%
  2. Mickey Thompson ATZ P3
    22.2%
  1. Oct 3, 2017 at 5:50 AM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I'm torn between the two. I know they are the near exactly the same tire. Same construction, materials and factory. Just looking for those with personal experience between the two or if you like the looks of one more than the other to help push me towards more one than the other.
    Cooper S/T MAXX:
    M/T ATZ P3:
    UPDATE:
    I ended up getting the Copper ST Maxx 285/70-17. Thanks.
    36505549_10212524680771709_4665769599533_94fd401ff8c1114e52b8e8d51dc0e77bc8bcf72d.jpg
    36518799_10212524681051716_1555719983055_7df4b0b274309cfa9aa5ad6a48326065516f2bfe.jpg
  2. Oct 4, 2017 at 11:36 AM
    Hilborn
    Michael
    Utah
  3. Oct 4, 2017 at 11:38 AM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Love my st maxx!
    Hilborn[OP] likes this.
  4. Oct 7, 2017 at 7:00 AM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Two totally different tires, the stmaxx have different rubber compounds, and different sidewall construction which is more puncture resistant as well as the tire carcass is stronger.. but both are good tires, either would be great, I have st maxx on my truck and love them.
    Trailbutter likes this.
  5. Oct 7, 2017 at 7:06 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I really love my st maxx. I have them in 255/80r17 and they're only $185 shipped, which is dirt cheap IMO.
  6. Oct 21, 2017 at 10:56 PM
    hammertaco11
    hammertaco11 Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    cant speak for these specific tires per se, but I went through 2 different sets through the years of Cooper Zeon LTZs and I LOVED them, so I'll probably go with the ST MAXX based on positive previous experience when I need some new rubber. Plus they look awesome
  7. Jul 8, 2018 at 3:36 PM
    Kardell31
    Kardell31 Well-Known Member
    St Maxx is a solid tire. Long wear life as well
  8. Oct 30, 2018 at 8:50 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Resurrection of this thread. MT $100/4 discount says it's time to reconsider.
  9. Oct 31, 2018 at 5:33 AM
    Hilborn
    Michael
    Utah
    I ended up going with the S/T Maxx
