Cooper STs in 265/75/16
Discussion in 'Wheels & Tires' started by stump jumper, Sep 29, 2015.
  1. Sep 29, 2015 at 11:00 AM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I found some in load C and load E. The respective weights are 45 & 49. I ran a set of Duratrac Cs on my 2009 for 30,000 miles and never had a problem on or off road. I am looking at the Coopers to replace my current BFG ATs when they wear out. Since the Cooper Es are the same weight as my BFG Ds I am strongly considering them. I need a tough tire where I hunt and the price difference on the Cooper is only $3. I see no reason not to go with them but would like to see the construction specs on the Cs before I do. I know what the specs are for the Duratracs and they are a little weak.
  2. Sep 29, 2015 at 11:34 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Link to the C rated?
  3. Sep 29, 2015 at 11:41 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    C rated just seems to hard to find. I just got the STT Maxx in E, same size. They are a bit heavier and rougher than my old Cooper ATP LT rated, but they are sooo much quieter!
    RogueTRD likes this.
  4. Sep 29, 2015 at 11:43 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Get the ST Maxx unless you absolutely need an M/T. I love mine.
  5. Sep 29, 2015 at 6:43 PM
    stump jumper
    Bill
    Texas
    Getting the ST not the STT. Max tread is not open enough for me. Found the Cs on one of the internet tire sites. It was Treadworks or something like that. I will try to find it again.
  6. Sep 29, 2015 at 6:53 PM
    stump jumper
    Bill
    Texas
    OnLine Tires.com has the STs in load range 112, 120, & 123. Never seen the 120 load range. They list as Es but maybe a D? I will probably go with the 120s
  7. Sep 29, 2015 at 7:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Just for clarification it's S/T Maxx, STT, STT Pro. But it's clear from this post that you don't want the S/T Maxx. I suggest updating the title for better comments.
  8. Sep 30, 2015 at 3:35 AM
    stump jumper
    Bill
    Texas
    Actually they are S/T not STT. I just left off the /
  9. Sep 30, 2015 at 5:04 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Actually we're both right.. I stand by clarification is needed. Apparently Cooper has a lot of similarly named tires.
  10. Sep 30, 2015 at 8:36 AM
    stump jumper
    Bill
    Texas
    Ok, I will make it perfectly clear. I am looking at the Discoverer S/T not the Max not the STT Pro which is more of a mud tire.
