Cooper tires
Discussion in 'Wheels & Tires' started by cr500taco, Dec 12, 2015.
  1. Dec 29, 2015 at 7:54 AM
    #41
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    @Rattletrap66 has them I'm pretty sure
  2. Dec 29, 2015 at 7:54 AM
    #42
    GreeGunc
    Jacob
    North GA
    On tread depot the p rated at3 are 38lbs, pretty sure that's what's on my truck.
  3. Dec 29, 2015 at 12:05 PM
    #43
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    I have them in the 305/70/16 size on my truck. TONS of photos in my build thread and my impressions on them. Great tire.
  4. Dec 29, 2015 at 12:17 PM
    #44
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    FWIW, I just put a set of Cooper A/TW's on my truck last month and finally got to test them in the snow today, and boy do they handle well in the snow. I used to think the Duratracs were decent in the snow, but with these A/TW's on the truck I don't even need it in 4WD to get around town in the snow. They handle pretty well in dry weather and are quiet on the highway too, but I did lose about 1MPG because the tires have a softer compound and/or because they are stock size (265/70-16) whereas the Duratracs were slightly larger (265/75-16). I have no regrets about getting the Coopers except that I wish I went with the larger size again.
    I think I'm going to keep these as winter tires and get a new set of wheels and larger A/T3's for summer use.
  5. Dec 29, 2015 at 5:09 PM
    #45
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    Getting 31"s on 15"s for now and stepping up to 33"s on 15"s in the future. I have a 3.4L. You didn't miss it. I thought I posted that, but I didn't.
    I don't off road much right now, but my truck so t setup suspension wise they way I want to, yet But, planning on getting that done, soon. Like the idea of having the ST Maxx because it is a little more aggressive, just in case I need them.
    I believe the KOs that I currently have are E rated.
  6. Dec 29, 2015 at 5:14 PM
    #46
    cr500taco
    D
    Northridge
    4WD
    Unfortunately, from what I have seen, the Maxx isn't offered in a skinny 33". But, I hope they will offer it I do not want to get wider wheels and fiberglass fenders to run the regular 33"s.
    #46
  7. Dec 29, 2015 at 5:18 PM
    #47
    cr500taco
    D
    Northridge
    4WD
    The only problem with the ATP's for me is that they are only offered at Discount tire, which there is one local by me. But, my concern is trying to find a Discount tire out on the road if I need a replacement.
  8. Dec 29, 2015 at 5:27 PM
    #48
    NateMob
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Probably the most popular tire chain in America honestly.
  9. Dec 29, 2015 at 5:29 PM
    #49
    GreeGunc
    Jacob
    North GA
    The st is available in 255s
  10. Dec 29, 2015 at 5:57 PM
    #50
    Trvlngnrs
    Trvlngnrs Well-Known Member
    The St Max is available in a C range for 33x12.5-15. I couldn't find a weight, but the SST Pro 33" C is 57lbs
    Understand your concern about not having a Discount Tire nearby. The AT3 is handled by anyone who sells Coopers, but it may not be as aggressive as you are looking for.
    Another option is the 255/75/17 or 255/85-16 You can get four 16" or 17" Toyota rims that owners have swapped out on Craigslist for $250-$300. Just make sure they match your hubs!
  11. Dec 31, 2015 at 3:52 AM
    #51
    cr500taco
    D
    Northridge
    4WD
    Ok, I wonder if they do lifetime alignment, like Firestone.
  12. Jan 1, 2016 at 3:09 PM
    #52
    NateMob
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    nope, they dont offer alignments.
  13. Jan 1, 2016 at 3:53 PM
    #53
    Trvlngnrs
    Does anyone know if the 265/75-16 ATP's come in C load range? The AT3's do, but I don't find the ATP in that size and load range on Discount Tires website.
    JimboAnz likes this.
  14. Jan 1, 2016 at 4:06 PM
    #54
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Great question, would like to know as well. Considering these tires in same size.
  15. Jan 1, 2016 at 4:20 PM
    #55
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I see them in load range SL......is this ok for our trucks?
  16. Jan 1, 2016 at 4:38 PM
    #56
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've had a set of P265/75/16 Cooper A/T3's on my Tacoma for 2 years and 35,000 miles. Don't under estimate them as an off road tire. Looks can be deceiving and I've found them to perform just as well in mud as any other AT tire. You'll have to move up to a true mud tire to do any better and even then the difference isn't as great as most folks think. I've been driving 4X4's for over 40 years and in my youth was convinced I had to have the most aggressive mud tire on my trucks. Over the years I've discovered that there are very, very few places I can't go with a decent AT tire. Driving skill trumps equipment every time. These have been excellent on snow/ice, as well as wet or dry pavement. They ride smooth and quiet.
    I talked to my tire dealer about LT's vs P's. He tells me he sees zero difference in the number of flats between them, but the P's will certainly ride much better than an "E" rated tire on a Tacoma. I've had a few flats over the years, some with LT's, some with P's. I can't tell any difference either. FWIW, if you look at the specs the P's are rated for exactly the same weight as a "D" rated LT and more than a "C" rated LT. I paid $480 OTD after the $80 rebate on my P's. I couldn't see paying more for a tire that would ride rougher and offer no advantage on a light truck. On a 3/4 ton yes, Tacoma, no. $480 for a tire that will last me over 50,000 miles is a steal.
    Noslackline likes this.
  17. Jan 4, 2016 at 4:29 PM
    #57
    Noslackline
    Noslackline Well-Known Member
    New England
    '15 TRD Sport DCSB 4X4 BRM
    X-2
    Recently went to the A/T'3's (265/65/17) and so far they are performing great....
    moe2o4 likes this.
  18. Jan 4, 2016 at 4:42 PM
    #58
    cr500taco
    D
    Northridge
    4WD
    Ugggh. You guys are making it difficult for me to decide. I was pretty much set on the Maxx. It's going to be a couple to a few weeks before I actually pull the trigger. So, I have time to research more.
    One tire that I haven't found much info on is the ATP. Is that in between the ST Maxx and the AT3? It looks slightly more aggressive than the AT3, but less than the ST Maxx.
  19. Jan 4, 2016 at 4:47 PM
    #59
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I had the ATPs on my 01 4Runner for 3yrs,great tire. Slightly more aggressive than the AT3,over 20k on them still looked new. Went through snow like a champ. However,they had a hum around 40ish mph that was quite annoying. I got a smokin' deal on my AT3s or I would've gone with the ATPs.
  20. Jan 4, 2016 at 4:51 PM
    #60
    cr500taco
    D
    Northridge
    4WD
    so, then you prefer the ATP's over the AT3?
