Copper washer size for oil drain plug gasket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xjasonblackx, Dec 14, 2024.
  1. Dec 14, 2024 at 4:25 PM
    xjasonblackx
    xjasonblackx [OP] New Member
    2022 Tacoma SR5 Double Cab
    Hey. I am new to my tacoma. I will be doing my fist oil change with it. My oem filter do not come with a gasket for the drain plug. I have an assortment of copper washers. That size would fit correct to be used for this? Thanks for the help guys. Glad to be here.
  2. Dec 14, 2024 at 4:31 PM
    Bishop84
    Bishop84 Well-Known Member
    Its designed with a nylon gasket in mind, just re-use it, they can be re-used 1 or 2 times no issue.
    Otherwise its a 10mm gasket the copper works.
  3. Dec 14, 2024 at 4:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Anything that fits on the drain plug should be fine
  4. Dec 14, 2024 at 4:47 PM
    xjasonblackx
    Oh great! Thanks, guys!
  5. Dec 14, 2024 at 4:52 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    t0p_d0g likes this.
  6. Dec 14, 2024 at 9:49 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
  7. Dec 15, 2024 at 2:22 AM
    guest_707
    guest_707 Well-Known Member
    Has anyone found a way to make it so that the damn washer doesn't stick to the oil pan during each oil change? It's especially a pain in the ass trying to get that thing off because I have the TRD skid plate which has an opening for the drain plug but I can't really see the gasket unless I look directly under the opening on the skid which means I'll have oil dripping into my eye hole.
  8. Dec 15, 2024 at 2:33 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    The gasket always sticks to my drain pan, and I just confirm it’s there by feel and pop it off with a small flat head screwdriver. It comes off easy and lands in the drain pan.
    Now here’s my question, the nylon gasket seems to have two different sides. Does it matter which way it’s installed?
    dryheat likes this.
  9. Dec 15, 2024 at 3:34 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I use plain aluminum ones now and have no issue. My Hondas never had the blue felt attached, so I figured it would be fine for Toyotas too. Haven't had any issues.
    Here's what I'm using:
    Dsnaduo 50PCS Aluminum M12 Crush Washer Oil Drain Plug Gasket Washer fit for Toyota Tacoma Tundra Camry Corolla 4Runner Scion Avalon Lexus, Replace 90430-12027 90430-12031 (22x12x1.4mm) https://www.amazon.com/dp/B09PBXR5RH
    Hook78 likes this.
  10. Dec 15, 2024 at 3:48 AM
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    The parts guy at my local dealer just gives them away like candy, ill usually ask to buy 2 and he hands me 3 or 4 no charge
    Suggestausername likes this.
  11. Dec 23, 2024 at 7:22 PM
    ISOLAT
    ISOLAT Member
    Jesse
    2023Tacoma,double cab, V6, TRD 4x4
    On Amazon I got the aluminum with the blue coating on both sides that looks identical OEM. The scary issues with many of these after markets is that the bolt becomes loose
    as the blue material softens with heat, sometimes to finger tightness. I will try DTaco18 route and go with the all aluminum ones that should work and is a great price for 50 washer....then there is the dealership.
  12. Dec 23, 2024 at 7:24 PM
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    Change to a Fumoto valve next oil change and never worry about your washer again
  13. Dec 23, 2024 at 8:04 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Just go to a dealer and get a bunch of proper oem gaskets. Might be a few bucks or may be for free. That's one thing I like to make sure works and fits.
  14. Dec 23, 2024 at 8:16 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Just go to the dealer and buy a few. they're cheap. dont by anything off ebay or Amazon.
  15. Dec 23, 2024 at 8:26 PM
    cbouch001
    cbouch001 Well-Known Member
    Charlie
    PNW
    2020 SR5 Taco
    OTT Tune, Bilstein 5100 with Icon RTX, SCS F5 , ARB Recovery point, MBRP Exhaust
    This
    If you are near a dealer. I know I know, many people have awful time with dealer. My local one is legit . The parts guys are super cool and super helpful. I got a bunch of gaskets for all the different parts.
  16. Dec 23, 2024 at 8:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Fuck Amazon. That guy doesn't need any more money
    Go to a locally owned parts store and buy a washer assortment. It'll cost about the same as 2 drinks from Starbucks
    dryheat and jonkassidy like this.
  17. Dec 23, 2024 at 8:48 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you talking about the oil pan drain plug gasket or the oil filter housing drain plug gasket? The latter is an O-ring that should be included with the filter.
    For the oil pan drain plug gasket, I've been using Dorman 12mm / 1/2" copper gaskets P/N 65271 for several years with good results. Doesn't stick to the pan, and no leaks on either of my Toyotas. It's available at most auto parts stores:
    https://www.napaonline.com/en/p/NOE7041354
    https://www.rockauto.com/en/moreinfo.php?pk=3936945&jsn=271
  18. Dec 23, 2024 at 8:52 PM
    jonkassidy
    jonkassidy Well-Known Member
    Huntington Beach Ca
    08 PreRunner SR5
    Limo tinted windows
    Dang I’ve been reusing the original washer that came with the truck for 4 years now.
    TheWildMan and dryheat like this.
  19. Dec 24, 2024 at 3:27 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I found a blue washer bolt finger tight a couple of years ago. Tripped me out. Hasnt happened since so wtf?
  20. Dec 24, 2024 at 5:16 AM
    DTaco18
    That's exactly what happened to me. Bought OEM washers on Amazon. Looked good and packaging seemed authentic. Found a couple finger tight with the blue coating oozing out the sides. Threw them in the trash. Now I'll only use dealer purchased OEM or non-coated aluminum or copper.
