Coppinger Cove Wheeling Trip! September 25-27
Discussion in 'South East' started by HappyGilmore, Jul 12, 2020.
  1. Aug 17, 2020 at 9:47 PM
    #281
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    What in the fuck happened to the bama thread?
    cubie likes this.
  2. Aug 17, 2020 at 9:48 PM
    #282
    nagorb
    Alabama
    2001 dbl cab 4x4
    Nevermind guess it's back up...
    cubie likes this.
  3. Aug 17, 2020 at 10:34 PM
    #283
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    it was lock for a couple hours
    cubie likes this.
  4. Aug 18, 2020 at 3:21 AM
    #284
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    What Jeff said or like you said weld it. Set screws suck for anything that you put any type of force on.
    cubie likes this.
  5. Aug 18, 2020 at 4:59 AM
    #285
    JBTacoma
    Jeff
    Cullman Alabama
    If he welds it he can't get it back off if he ever needs to or needs to replace the shifter seat
    cubie and ovrlndkull[QUOTED] like this.
  6. Aug 18, 2020 at 6:53 AM
    #286
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Cutoff wheel:devil:
    cubie and Brian422 like this.
  7. Aug 18, 2020 at 6:57 AM
    #287
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    honestly the shifter isnt my main concern its not being able to shift gears properly which i cant seem to figure out because it doesnt make sense. Nothing was altered or changed besides the shape of the handle.
    cubie likes this.
  8. Aug 18, 2020 at 7:02 AM
    #288
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Is it hitting something preventing the shifter from moving correctly? Also try rocking the truck
    cubie, JBTacoma and Brian422[QUOTED] like this.
  9. Aug 18, 2020 at 7:03 AM
    #289
    JBTacoma
    Jeff
    Cullman Alabama
    I would get it all finished and drive it to see how it all works. I have had my transfer case not want to go into gear until I move the truck. Sometimes things just have to align to slip into place.
  10. Aug 18, 2020 at 7:05 AM
    #290
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Idk because i cant see in the case when i have the handle in but it takes like 6 or 7 super hard pulls on the shifter to get it where i want it and then it still doesn't make the engagement sound that it was making. It is engaging though because i jacked the rear end up and spun the driveshafts to confirm.
    cubie likes this.
  11. Aug 18, 2020 at 7:34 AM
    #291
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Like Jeff said you probably need to get it driving and things moving around. It may be some of the gears aren't quite aligned
    cubie and Brian422[QUOTED] like this.
  12. Aug 18, 2020 at 7:40 AM
    #292
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    But why would they not align when i spin the shaft?
    cubie and HappyGilmore[OP] like this.
  13. Aug 18, 2020 at 7:59 AM
    #293
    JBTacoma
    Jeff
    Cullman Alabama
    Not sure that it isn't but the only things left to do is make sure the shifter is installed correctly, finish it and try it out moving with gear oil in it or tear the gear box apart to see why. It could also be as you said the shifter may not have enough leverage the way it is design and making it hard to shift. It would be interesting to see what a non-cut shifter would do.
  14. Aug 18, 2020 at 8:03 AM
    #294
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Damn this would make it so much easier for me to figure out if the truck was at my house. It just takes too much time to go up there after work during the week to figure it out.
    cubie likes this.
  15. Aug 18, 2020 at 8:13 AM
    #295
    JBTacoma
    Jeff
    Cullman Alabama
    I wish I knew the answer buddy
    cubie likes this.
  16. Aug 18, 2020 at 8:29 AM
    #296
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I bet it’s leverage issue. That’s the only thing that makes sense
    cubie likes this.
  17. Aug 18, 2020 at 8:31 AM
    #297
    JBTacoma
    Jeff
    Cullman Alabama
    Could be
    cubie likes this.
  18. Aug 18, 2020 at 8:45 AM
    #298
    HappyGilmore
    HappyGilmore [OP] LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    did you have someone trying to engage it while you were spinning the shaft? gears could be like >< and not totally engaging? or maybe when you re-installed the shifter something got bound up. Just my initial thoughts having minimal knowledge on the subject.
    cubie likes this.
  19. Aug 18, 2020 at 8:51 AM
    #299
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    no i did not, ive uninstalled and reinstalled the shifter too many times to count in a million different ways. Following this video. go to 4:20
    https://www.youtube.com/watch?v=9nTfcHxDK-8
    cubie likes this.
  20. Aug 18, 2020 at 8:54 AM
    #300
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    you can hear the shifter making the engagement noises as he shifts. Mine only makes noise in 4lo right now for some reason and is very hard to get out of 4lo/ neutral.
    cubie likes this.
