Core / Hurst short throw shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Apr 23, 2013.
  1. Sep 3, 2015 at 3:19 PM
    #261
    Dougj
    Dougj New Guy
    Doug
    Prather, CA
    Make sure you assembled the lever to the shifter base with the serrations together. If you put the lever on with the smooth side to the shifter it will loosen up. Use plenty of blue loctite as well.
    Ask me how I know...
  2. Sep 3, 2015 at 3:20 PM
    #262
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    @VolcomTacoma
    Like deeez said, I would definately check the bolts on the stick. Mine almost fell off while driving when I first installed.
  3. Sep 3, 2015 at 3:26 PM
    #263
    samiam
    Sam
    Stinky Vegas
    Did the stick fall off?
  4. Sep 3, 2015 at 3:59 PM
    #264
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Pretty sure I put it on the right side...putting it any other way just seemed counter productive, put I'll pull it apart tonight and get a look. Something tells me its just normal manual slop or something and In my head it just seems excessive.
  5. Sep 3, 2015 at 6:21 PM
    #265
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Mines reversed with a spacer wedged in between. This kit enabled me to move the shifter over towards the drivers side which I hope will make the triple stick mod easier to achieve.
  6. Sep 3, 2015 at 7:33 PM
    #266
    VolcomTacoma
    Jeff
    NorCal
    Parked out front of work, truck is off, but this is the same slop it always has...thats in first gear I pulled the cupholders out and snaked a hand inside to feel everything, this is definitely the Core Shifter and not just the stick....
    Annnnnd TW wont let me upload my video from my phone lol. Guess ill try tomorrow when i get home. Slop is about an inch to left or right and about 2" forward and back, with foot off of clutch
  7. Sep 3, 2015 at 8:52 PM
    #267
    samiam
    Sam
    Stinky Vegas
    That's not normal. Mine moves 1/2 inch front to back, and almost none side to side.
  8. Sep 3, 2015 at 9:35 PM
    #268
    NotRed
    NotRed Well-Known Member
    :jellydance:
  9. Sep 3, 2015 at 9:37 PM
    #269
    NotRed
    'bout the same as mine.
  10. Sep 3, 2015 at 10:36 PM
    #270
    VolcomTacoma
    Jeff
    NorCal
    Well fuck
    CASHORT and deeezy like this.
  11. Sep 4, 2015 at 12:41 PM
    #271
    VolcomTacoma
    Jeff
    NorCal
    Finally got the video uploaded.
    I'm thinking the white bushing is deformed or gone at this point, allowing it to move around so much more. I emailed Core but got no response. I'm going to open her up as soon as I can get the baby asleep lol
  12. Sep 4, 2015 at 12:45 PM
    #272
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Yup, you're probably right about the bushing being damaged/worn out.
  13. Sep 4, 2015 at 12:52 PM
    #273
    VolcomTacoma
    Jeff
    NorCal
    Well, Luckily I've got the stock one still, I'll just have to pry it off and reuse it. Maybe I'm shifting to hard or something for the bushing?
  14. Sep 4, 2015 at 2:33 PM
    #274
    deeezy
    Dana
    Hawaii
    Must be all that rubber you're laying down w/ the SC. :burnrubber:
  15. Sep 4, 2015 at 3:25 PM
    #275
    VolcomTacoma
    Jeff
    NorCal
    Ok so core said he'd be willing to replace whatever is wrong, upon further investigation, the bushing doesn't seem that worn out, but its got a little bit of slop in it, when I pulled it off it still looked pretty new, no uneven wear on it or anything. But it definitely moves a good 1/8" or so wiggling on the shaft. The OEM one just rolls as normal with zero slop. HOWEVER, after getting everything pulled apart I come to find out the Hurst Core shifter does not use the same ball end as the OEM shifter, so the bushing on the oem just pops right on to the hurst shifter and falls right back off. FML.
    I will admit the shifter bar was a hair loose on the mechanism, so i snugged it way down and threw some more loctite on it. But now that's its all back together I still have alot of slop. Hopefully i can get Core to send me a couple bushings so I have spares if/when this happens again
  16. Sep 4, 2015 at 3:41 PM
    #276
    NotRed
    No suggestions here; my 5 speed shifter did not come with the ball-end bushing and the instructions covered removing the existing one and moving it to the Hurst unit.
  17. Sep 4, 2015 at 3:43 PM
    #277
    VolcomTacoma
    Jeff
    NorCal
    Yea, the hurst shifter came with a pre-installed bushing. I asked Core if he knows where I can source a better bushing or if he'll toss a couple my way. Hopefully he's cool about it and doesn't make me do it on my own lol
    deeezy likes this.
  18. Sep 4, 2015 at 5:53 PM
    #278
    VolcomTacoma
    Jeff
    NorCal
    Ok so Core wants me to ship it back lol, i told him id prefer not to, id rather just get a couple spare bushings, as the shifter body looks fine, i have a feeling im just shifting to roughly and wore out the bushing or something.
  19. Sep 5, 2015 at 1:20 PM
    #279
    VolcomTacoma
    Jeff
    NorCal
    UPDATE- Core say's he machined a new bushing partially made from glass or with glkass added to the mix, to be stronger, I suppose? Shipping out soon!
    deeezy likes this.
  20. Sep 5, 2015 at 11:25 PM
    #280
    mooddog280Z
    mooddog280Z Active Member
    Southeast Kansas
    08 DC TRD Sport 6 Speed
    Dipped Badges
    Was curious if anyone had a video of running through the gears with the core/hurst? Only one I can find is the NV3500 kit, and I figured it would be apples to oranges.
