Core-Shifter for 3rd Gen V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bbrown, Jan 26, 2019.
  1. Feb 21, 2021 at 6:33 PM
    #321
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yep
  2. Feb 21, 2021 at 6:34 PM
    #322
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I have one of the @7r41lbr34k3r shift knobs with his delrin adapter (works like stock), and it fits fine. I think it sits slightly higher than stock, but not by much. I stretched the inner stock boot around the shifter, installed the CORE boot, then the outer stock boot. Just looking at it, aside from the knob, you would never know it wasn't stock.
    poopshute[QUOTED] likes this.
  3. Feb 21, 2021 at 8:41 PM
    #323
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Thanks! This is exactly the setup I would run if I go the CORE route. Does Richard (Trail Breaker) sell adapters that allow the standard Toyota thread to attach to the core shifter? If so, I’ll contact him when/if the time comes.
  4. Feb 22, 2021 at 5:06 AM
    #324
    su.b.rat
    su.b.rat broken truck
    you will need to get the adapter separately. the Core is 3/8-16.
    how heavy is the knob you have? i used a 700g monster on my URD stocker, but i use a knob under 200g for the Core. totally different feel so how the weight is on your stock unit will feel very different on the Core and you may like different weighting possibly.
  5. Feb 22, 2021 at 5:18 AM
    #325
    lapoltba
    CT - 06076
    No, it's under $15 shipped from a bunch of places linked in this thread. It was talked about and linked to (by me and others) within the last few pages.
  6. Feb 22, 2021 at 8:12 AM
    #326
    trdteddyb
    trdteddyb Well-Known Member
    2020 TRD Pro MGM 6MT
    How often does Core replenish their stock? It says check back in a couple weeks
    Hofmann’s Tacos and poopshute like this.
  7. Mar 8, 2021 at 2:07 PM
    #327
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    How does the parking brake boot come off? Do you just wiggle it off over the handle?
  8. Mar 8, 2021 at 2:14 PM
    #328
    lapoltba
    CT - 06076
    I found it easier to pop it out of the console and leave it attached to the lever. Its just a loop of wire that clips into the underside of the console.
  9. Mar 8, 2021 at 2:20 PM
    #329
    asciimike
    asciimike Member
    Denver, CO
    2021 MT TRD OR DCSB
    Core short shifter w/TRD ball, pro tails
    I basically did this as well... sorta just left the console connected to the parking brake and rotated it out of the way. It wasn't super elegant, and was honestly a bit of a pain to work around, but worked fine in the end.
  10. Mar 8, 2021 at 2:21 PM
    #330
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    My parking boot slipped right over the handle no problem. Went right back on also.
  11. Mar 15, 2021 at 4:24 PM
    #331
    wolf2600
    San Jose, CA
    Coyoza Tuned
    C41n, pinochle, JDSmith and 3 others like this.
  12. Mar 15, 2021 at 4:48 PM
    #332
    bbrown
    bbrown [OP] Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    Looks good. The flex head ratchet wrench is the way to go.
  13. Mar 15, 2021 at 5:39 PM
    #333
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    [QUOTE=" [​IMG]
    :burnrubber:[/QUOTE]
    Sometimes I come back to this thread just to look at this picture. It's so beautiful.
    JDSmith, bbrown[OP] and wolf2600 like this.
  14. Mar 17, 2021 at 6:32 AM
    #334
    wolf2600
    San Jose, CA
    Coyoza Tuned
    Also, anyone else find that getting into reverse takes significant effort?
    Pushing the stick to the far left, the spring(?) mechanism is really strong.
    Does that improve over time?
    On the factory shifter, there was no resistance and it was always a question as to whether you're putting in in R or 1st, but with the Core shifter, it takes some serious muscle to go to R.
  15. Mar 17, 2021 at 9:14 AM
    #335
    bbrown
    Buster
    Geauga County Ohio
    255/85R16 ST MAXX
    I don’t think it breaks in much, but you do get used to it. I actually appreciate the increased resistance to get into reverse as you will be less likely to accidentally select it instead of first. I also use more a slapping motion (momentum) to get into reverse vs. just slowly trying to select reverse.
  16. Mar 17, 2021 at 10:41 AM
    #336
    poopshute
    Colorado
    Just a quick update. Core-shifters says they're still a few months out from getting their stock replenished due to the continuing supply chain issues. Patience will be tested for all of us waiting!
    bmxtaco likes this.
  17. Mar 17, 2021 at 7:44 PM
    #337
    lapoltba
    CT - 06076
    It definitely takes more effort than stock, but I think some of that is the additional precision required to get it in the gate. I had the habit and muscle memory of a slap motion for reverse already so it didn't take much to get used to. I feel like mine has broken in a tiny bit, but not much. I think you just get used to it after driving a while. Regardless, the feel of shifting the rest of the gears far outweighs the minor increase in difficulty of reverse for me.
    C41n and wolf2600[QUOTED] like this.
  18. Mar 17, 2021 at 8:48 PM
    #338
    poopshute
    Colorado
    I’m actually happy to hear this! One of the reasons I want to move to a short throw shifter is to firm up reverse. I’m one of those who will get too aggressive with the stick in a panic situation and fly past first into reverse. Doesn’t happen often but it does happen.
  19. Mar 18, 2021 at 5:42 AM
    #339
    lapoltba
    CT - 06076
    Firm up is an understatement when you are comparing to the floppy stock shifter with the rubber isolator in it.
  20. Mar 18, 2021 at 1:47 PM
    #340
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Yes but it’s way better IMO. Just like others have said, I really appreciate the fact it’s harder to accidentally throw it in reverse. Slap method - this is the way
    wolf2600[QUOTED] and poopshute like this.
