Core-Shifter for 3rd Gen V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bbrown, Jan 26, 2019.
  1. Oct 31, 2019 at 7:58 PM
    #101
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    I can’t get that rubber line on the fitting all the way to the top of the brass fitting
  2. Nov 1, 2019 at 4:11 AM
    #102
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    I had the same problem because, as you know, there's not much room to maneuver your hands. My advice...just keep working with it and you'll get it.
    Put some lube on it and try some bent nose needle nose pliers.
    With that said mine is probably not 100% on there either but pretty sure it's good enough.
    It's a breather line, so not sure how much pressure goes thru that line? I'm thinking not a lot.
  3. Nov 1, 2019 at 7:56 AM
    #103
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    Just pulled the trigger on one for my 2.7 5spd - hopefully combined with the new clutch pedal TSB and accumulator delete the shifting will at the very least be consistent every time.
  4. Nov 1, 2019 at 8:02 AM
    #104
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Folks say that there is no accumulator on the 2.7l. At the bottom of the ADM thread OP, there is a pic of the 2.7l clutch line parts. I don't doubt folks, but I have asked for a confirmation pic in the area of the slave cylinder. That said, some SR MT folks have said that they get odd clutching from time to time.
    Also if your poking around, there has been some discussion if the 2.7l SR came with or without a front sway bar. What's on yours?
    Have a good one.
  5. Nov 1, 2019 at 8:11 AM
    #105
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Interesting. My SR does shift more smoothly than any 3.5 6spd I’ve had the chance to drive - but I figured that was simply the R156F, it pairs correctly with the 2.7. Good to know.
    tonered[QUOTED] likes this.
  6. Nov 1, 2019 at 8:14 AM
    #106
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem! The accumulator does screw up the engagement. Butter with it gone.
    Anything on the sway bar?
  7. Dec 11, 2019 at 10:22 AM
    #107
    NapaMT
    NapaMT Active Member
    2019 DCSB 4x4 OFF-ROAD MT
  8. Dec 11, 2019 at 6:46 PM
    #108
    Kcm10883
    Kcm10883 Well-Known Member
    2019 Cement DC TRD Off Road
    how come you're getting rid of it @NapaMT
  9. Dec 11, 2019 at 8:29 PM
    #109
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    It has a sway bar. Don’t see why some models wouldn’t..
  10. Dec 11, 2019 at 8:48 PM
    #110
    NapaMT
    I guess it just didn’t provide the feel I was looking for, I’m fairly picky and just knew it wasn’t going to work for me. Now it’s just siting on shelf in the packaging it came in waiting for someone else to try it and hopefully enjoy it.
  11. Jan 8, 2020 at 5:36 PM
    #111
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    Planning on installing this tomorrow. Is it possible to fit a full size 1/2" drive torque wrench into the shifter area to tighten the base bolts? Or do I need a 3/8" drive torque wrench?
  12. Jan 8, 2020 at 6:01 PM
    #112
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    From everything I've read about installing a short shifter, you'll only be able to to get a ratcheting swivel head box end wrench in there so I think everyone just torques to 1.5-2 ugga duggas.
    WalkinTaco likes this.
  13. Jan 8, 2020 at 6:49 PM
    #113
    bbrown
    bbrown [OP] Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    I put on some blue loctite and tightened it “snug” using a flex head ratcheting box end wrench. That is about all you can fit on the front bolts.
  14. Jan 9, 2020 at 2:50 PM
    #114
    TacoJeff19
    Jeff
    19' DCSB OR
    Well got this installed was pretty easy besides the front bolts. Even with a ratcheting flex I had to crawl under the truck and get a helper to put the ratchet on the bolts. Forgot to put loctite on the 4 base bolts unfortunately. Hopefully I don't have to go back to add loctite. Would y'all recommend adding loctite?
  15. Jan 9, 2020 at 3:03 PM
    #115
    bbrown
    Buster
    Geauga County Ohio
    255/85R16 ST MAXX
    Loctite was for peace of mind. I don’t think they had loctite from the factory.
  16. Jan 9, 2020 at 3:10 PM
    #116
    TacoJeff19
    Jeff
    19' DCSB OR
    Oh I see, good to know. I figure I'll go back maybe by my next service and check the bolts.
    bbrown[OP] likes this.
  17. Feb 20, 2020 at 8:48 PM
    #117
    fake4x4
    Cool stuff
    were you able to get the breather line over that fitting?
  18. Feb 20, 2020 at 9:12 PM
    #118
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine needs a fluid swap. Kinda typical, have a little over 4K on the factory fill, getting notchier and notchier. I will look at the Hurst shifter in the summer, I have so much STUFF I haven't installed yet.
    fake4x4 likes this.
  19. Feb 20, 2020 at 9:18 PM
    #119
    TacoJeff19
    Jeff
    19' DCSB OR
    Yes I just wiggled it slowly till I got it about 90% of the way on
  20. Feb 20, 2020 at 9:19 PM
    #120
    TacoJeff19
    Jeff
    19' DCSB OR
    Mine is SOOO notchy. Sometimes I wonder if I have clutch drag from doing the ADM but j really think I just need to swap to redline gear oil
