Core-Shifter for 3rd Gen V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bbrown, Jan 26, 2019.
  1. Feb 20, 2020 at 9:27 PM
    #121
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    whats clutch drag?
  2. Feb 20, 2020 at 9:33 PM
    #122
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    Well you've heard of clutch slip which is where the clutch applied with full pressure to the flywheel on the engine when the clutch is connecting the engine to the trans. Slip gives you the situation where you give the engine gas and the rpms increase but your speed does not.
    Drag is usually a byproduct of slip. But not always. Drag is when you disengage the clutch and it does not fully disconnect from the flywheel causing more effort to be needed to engage a gear or disengage a gear.
    fake4x4[QUOTED] likes this.
  3. Feb 20, 2020 at 9:48 PM
    #123
    fake4x4
    Cool stuff
    I think I feel that when the trans is cold
  4. Feb 20, 2020 at 10:05 PM
    #124
    TacoJeff19
    Jeff
    19' DCSB OR
    Yeah sometimes I think clutch drag but it's probably not.
  5. Feb 21, 2020 at 4:02 AM
    #125
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Is anyone able to articulate the differences between this and the urd? The urd was a pretty good improvement over stock but the shifter is still my biggest gripe with the driving experience.
  6. Feb 21, 2020 at 5:35 AM
    #126
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    pinochle likes this.
  7. Feb 21, 2020 at 6:14 AM
    #127
    TacoJeff19
    Jeff
    19' DCSB OR
    This is a solid one piece shifter and base the urd is just a modified stock shifter to shorter. I don't have experience with the URD one but I hear it degrades after time. I've had another core shifter in a different vehicle and it's 100% amazing hands down. Only draw back is the gear noise takes some getting used to
  8. Feb 21, 2020 at 6:15 AM
    #128
    TacoJeff19
    Jeff
    19' DCSB OR
  9. Feb 21, 2020 at 7:44 AM
    #129
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Around 2.6 qts, seems like a lot clings and hides in most trannies......but still need to have 3 quarts.
    tonered likes this.
  10. Mar 18, 2020 at 11:15 AM
    #130
    xxtavixx
    Jacksonville fl
    2018 6MT
    Core-Shifter is tighter/shorter than the URD. The re-positioning the half inch to the driver is very comfortable. Much easier install than URD.
    The thing is damn noisy. It's loud. I've got S/T maxx tires and this is louder than they are. Fourth gear is the least noisy, 6th seems to be the worst. It's not just noisy, it's obnoxious. I'm not sure if this will be in the "Get used to it" category or the "slowly annoy me to death"
    tonered likes this.
  11. Mar 18, 2020 at 12:04 PM
    #131
    bbrown
    bbrown [OP] Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    You get used to it. 6th is loudest because the output shaft on the trans is turning at its max rpm - making the most noise. The Core Shifter is all solid metal to avoid slop/play - so vibrations transmit easy. You could try a piece of rubber between the lever stub on the base assembly and the shift stick.
  12. Mar 18, 2020 at 2:44 PM
    #132
    Kcm10883
    Kcm10883 Well-Known Member
    2019 Cement DC TRD Off Road
    Would it be possible to wrap the metal with something that’s vibration/dampening like idk dynamat or some sort of sound deadening material?
  13. Mar 18, 2020 at 3:02 PM
    #133
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    Anyone willing to post up a video of how loud it is in the cabin?
    Kcm10883 likes this.
  14. Mar 18, 2020 at 3:50 PM
    #134
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    I don't get it. I can barely hear the difference and its certainly not annoying. :confused:
    About the only sound is a slight vibe occasionally only when stopped or sitting at a light if I leave it in gear.
    It stops when you put your hand on the knob.
    One thing... I did trim the secondary boot to fit tightly around the shift lever (trying to avoid saying shaft and knob in the same post, LOL)
    It does have a distinct "snick, snick'' sound when you change gears but that sounds really good to me.
    Maybe (probably) I have bad ears?
  15. Mar 18, 2020 at 4:37 PM
    #135
    xxtavixx
    Jacksonville fl
    2018 6MT
    can confirm you have bad ears.
    its ever so slightly less noisy with hand on knob. I have both boots on mine, i pulled the staples.
    it sounds like a like a ridiculously small blower when you leg the throttle. Thats cool.
    I think I will get used to it, did an hour trip in it and it started to be background noise
    fake4x4 likes this.
  16. Mar 18, 2020 at 7:13 PM
    #136
    fake4x4
    Cool stuff
    I love the sound of the synchros and this clunky Toyota trans!!
  17. Mar 23, 2020 at 10:39 AM
    #137
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    We know the Hurst shift knob is 3/8 on 16 for thread.
    Anyone know if the o.e. shift knob in a 3ed gen manual is the same?
  18. Mar 23, 2020 at 11:00 AM
    #138
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nope. We're metric threads.
    su.b.rat likes this.
  19. Mar 23, 2020 at 11:20 AM
    #139
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Far from a transmission expert but wouldn't the output shaft speed be tied directly to the speed of the vehicle regardless of what gear the trans is in?
  20. Mar 23, 2020 at 11:26 AM
    #140
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. But the secondary and output shafts will typically be turning the fastest in 6th gear and the motor will be the quietest. It is probably a combination of all that for the noise.
    It sounds right up my alley, but I don't want the Hurst shaft or knob. If the Core folks ever get their head on start, I will grab one.
