Correct alignment Question?
Discussion in 'Suspension' started by Coyboy 0351, Dec 30, 2010.
  1. Dec 30, 2010 at 1:06 PM
    Coyboy 0351
    Coyboy 0351 [OP] Well-Known Member
    MINNESOTA
    Sport Dbl Cab 4x4
    OME 3'' w/ OME nitro sport shocks.. 2'' blocks rear w/ OME sport shocks.
    Sorry if this has been asked already. I am having some wondering wheel issues and was told to get the camber and caster adjusted. I had my wheels aligned and everything is in the green. I have fox light racing UCA's so they can be adjusted. Are there specific numbers that I should have for my alignment?
  2. Dec 30, 2010 at 1:10 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    from chris 4x4
    If you have 285s or some other 33s I would recommend above 2.6 caster to attempt to avoid the body cab mounts somewhat.
  3. Dec 30, 2010 at 1:17 PM
    Coyboy 0351
    MINNESOTA
    Sport Dbl Cab 4x4
    Thanks, I have 265x 70 17's. Should I go to Toyota to get it done or is Tires Plus OK?
