Correct battery for 2017 with tow package?
Discussion in 'Towing' started by zenny, Jul 23, 2018.
  1. Jan 4, 2019 at 4:54 PM
    #41
    Calion
    Calion Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    Okay, that's what I figured from what I've read: Make sure you have enough CCAs, and then get as many RCs as you can. That makes the 24F better, because it's a bigger battery.
    However, I've been wondering: A better battery is almost definitionally heavier. How much does an extra few pounds of weight affect mileage over the, say, 5 years you'll have the battery?
  2. Jan 4, 2019 at 5:18 PM
    #42
    Calion
    So I got curious about this, and, using what is apparently the industry standard of 1% decrease in gas mileage for every 100 pounds, a 2-pound difference in battery weight works out to—about $1 over five years.
    PB FAB likes this.
  3. Jan 4, 2019 at 8:05 PM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 24F is a smaller battery with less CCA
  4. Jan 4, 2019 at 8:46 PM
    #44
    Calion
    shakerhood[QUOTED] likes this.
  5. Jan 4, 2019 at 8:48 PM
    #45
    shakerhood
    Southern Ohio
    Sorry I thought you were comparing Factory Tacoma Batteries of 24F and 27F.
  6. Jan 4, 2019 at 8:50 PM
    #46
    Calion
    Ah. My 1st Gen shipped with a 35 but apparently fits a 24F as well.
  7. Jan 5, 2019 at 1:09 PM
    #47
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Any recommendations on brand of AGM battery?
  8. Jan 5, 2019 at 2:34 PM
    #48
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    I worked for Interstate Battery for many years so my 1st inclination is to go there. Just the same, any AGM in and of itself is superior to any wet lead acid type. Shop around. Compare CCA's, CA's, and RC values along with cost and warranty. That market is heating up and getting competitive.
    SCRob likes this.
  9. Jan 5, 2019 at 5:23 PM
    #49
    Calion
    The bunch of research I've done in the last couple of days indicates that Deka Intimidator is a really good option, as is Northstar/X2 if you've got the dough. Edit: Odyssey also comes highly recommended. Optima apparently used to be awesome, but is no longer, which is sad, because they're the only ones that sell spiral-cell AGMs, which are significantly more resistant to off-roading vibration.
  10. Jan 5, 2019 at 5:38 PM
    #50
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Odyssey or Northstar
    (Hardwood spacer not included)
    polaris202, Daemon671 and shakerhood like this.
  11. Jan 5, 2019 at 6:57 PM
    #51
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I don't think there will be any noticable difference between the 24F and 27F batteries for 99.9% of owners.
    The extra weight might bend the radiator support while off roading. Less weight is generally better.
    If you need house power or the like, running a second battery is probably a better idea.
    That being said, the stock OEM battery is garbage from my experience. 1st replaced under warranty, the other seems to leak a little as I get lots of corrosion at the terminals and hold down.
    Go AGM.
    EagleUSMCRet likes this.
  12. Jan 6, 2019 at 4:31 AM
    #52
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    Back in the day, I supplied lots of Odyssey's to NASCAR Infinity Series teams in North Carolina. (Go's to reliability and testing) Spiral cells are just so-so. If that were the way to make 'em, everybody would make 'em like that. Saw my share of failures with that brand. Good luck finding a Northstar distributor when you have an issue and Deka distribution is very spotty. They are around, but just not around every corner. Just 'cuz you buy an AGM, don't assume you will never have an issue. Like anything else, mass produced and subject to failure. Where you buy it matters just as much.
    SCRob likes this.
  13. Jan 6, 2019 at 9:15 AM
    #53
    Calion
    I had thought that it was a patent issue, that Optima has the patent for spiral-cell in North America.
  14. Mar 6, 2019 at 4:59 AM
    #54
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    Thats not true
    If you got a v6, then you have the tow package... SR5 comes standard...
  15. Mar 6, 2019 at 6:13 AM
    #55
    shakerhood
    Southern Ohio
    So you have a 16 or 17 and it was standard? I have a 17 and it was optional, I thought it became start equipment on V6 in 2018.
    Pella likes this.
  16. Mar 6, 2019 at 6:37 AM
    #56
    shakerhood
    Southern Ohio
    Here is my 2017 window sticker and it's a $650 option, do you by chance have the window sticker from yours showing it as standard?
    Pdxsteve likes this.
  17. Mar 6, 2019 at 6:58 AM
    #57
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    X2 Power, 27f AGM made by Northstar, I believe. Replaced 3 year old original with this for winch and other accessories. Especially while camping. Good specs, 5 year full replacement warranty. 20% off through March 7.
  18. Mar 6, 2019 at 8:00 AM
    #58
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Shakerhood is correct, in 2016 and 2017, the tow package was a option that needed to be added on, even on a V6. In 2018, it was standard. My truck is a V6 Sport and i dont have the Tow Package.
  19. Mar 6, 2019 at 8:10 AM
    #59
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    I need to get a better battery than the 24F in the 18 Tacoma. Live in the northeast and am on my 3rd battery in 5k miles. Only the truck is on the battery. No outside draws. The resting voltage in these batteries drop exponentially over time/cold and seem not to hold a charge well. The CCA is 560 on the OEM battery. My girls civic has a larger battery and more CCA.
  20. Mar 6, 2019 at 9:12 AM
    #60
    Pot_Lickr
    Ontario, Canada
    Well... Must be a Canada thing..
    I wanted an SR5 at first... All come with standard tow package..
    Everyone I looked at all have tow package..
    This was 2017 models..
    shakerhood and TacoTruck808 like this.
