Correct Cam Bolt Assembly Part Numbers, and Bushing Part Numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Nov 27, 2015.
  1. Dec 15, 2015 at 9:07 AM
    #41
    Pigpen
    Dan
    Northwest Montana
    So funny!! We all bought them. Some guy in parts is thinking "what's with all these orders that include an unrelated part"?
    At least they are inexpensive and will probably work for something else on the truck.
    It'll be interesting to find out where they fit.
  2. Dec 15, 2015 at 9:32 AM
    #42
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So besides that one part number do we all the correct rest of the parts to do the job?
  3. Dec 15, 2015 at 10:01 AM
    #43
    Large
    Large Red
    We will see I guess lol. I can't really touch the truck until next weekend but I can open the box tonight
  4. Dec 15, 2015 at 10:02 AM
    #44
    Unchained 5150
    Rick
    Auburn Ma
    Thanks man let me know
  5. Dec 20, 2015 at 1:47 PM
    #45
    Large
    Large Red
    Unboxed everything, put my new bushings and sleeves together. I think I am missing something still. Anyone else try to piece this together yet?
  6. Dec 20, 2015 at 2:00 PM
    #46
    Large
    Large Red
    OK! If you look closely you will see the problem. Remember the 2 bolts where we said "wtf are these for?" Well the part number we ordered was 90119-A0116 and we actually needed part number 90119-A0166 :facepalm: It's alright though as I still don't have time to work on the truck yet. Making hopefully my last order here in a minute or so. :fingerscrossed:
  7. Dec 20, 2015 at 2:08 PM
    #47
    Large
    Large Red
    Found this in another thread, thanks pugs:
  8. Dec 20, 2015 at 3:03 PM
    #48
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :thumbsup:
    Large[QUOTED] likes this.
  9. Dec 20, 2015 at 4:09 PM
    #49
    Unchained 5150
    Rick
    Auburn Ma
    Okay so what In my delivered box do I need and not need now @Large
  10. Dec 20, 2015 at 4:31 PM
    #50
    Large
    Large Red
    The 2 small bolts aren't needed (they look like the e-brake bolt actually) and the 2 long bolts that I mentioned up top you need.
  11. Dec 20, 2015 at 4:32 PM
    #51
    Unchained 5150
    Rick
    Auburn Ma
    That will complete the set brother? Was thinking even though the truck is new to replace the bushings at the same time. You have a link for those as well man?
  12. Dec 20, 2015 at 4:38 PM
    #52
    Large
    Large Red
    I got delrin bushings from kar-tek but they won't be the ones you need. I have aftermarket lower control arms. If you remove the (2) 90119-A0116 and add (2) 90119-A0166, and I had a QTY of (4) 48198-60011, you only need 2. That should be it.
  13. Dec 20, 2015 at 4:43 PM
    #53
    Unchained 5150
    Rick
    Auburn Ma
    Okay so now I am totally confused now because you list this in the new part list 4845235030 2 EA and we all ordered 4845235020
  14. Dec 20, 2015 at 4:44 PM
    #54
    Unchained 5150
    Rick
    Auburn Ma
    So how about someone do a complete updated parts lists because 2 part numbers have changed and quantities have changed
  15. Dec 20, 2015 at 4:47 PM
    #55
    Unchained 5150
    Rick
    Auburn Ma
    If you haven't unwrapped everything @Large show all the pics of numbers you have.
  16. Dec 20, 2015 at 5:03 PM
    #56
    Large
    Large Red
    Everything there, except the one part that says qty of 4, it should be 2. The first part number should be 90119-A0166.
    This is what I'm left with:
  17. Dec 20, 2015 at 5:04 PM
    #57
    Large
    Large Red
    Where as the 2 small bolts should be the long ones, and the 2 cam tabs aren't needed.
  18. Dec 20, 2015 at 5:09 PM
    #58
    Unchained 5150
    Rick
    Auburn Ma
    So you have those 2 useless little nuts and bolts left. And what two 4819860011
  19. Dec 20, 2015 at 5:11 PM
    #59
    Unchained 5150
    Rick
    Auburn Ma
    So what holds the smaller assemblies together brother?
  20. Dec 20, 2015 at 5:14 PM
    #60
    Large
    Large Red
    What holds the 2 smaller ones together is the long threaded bolts that I didn't order (90119-A0166). The cam tab on one end is threaded and the other end is smooth. Yes the 48198-60011 I ordered 4 and it should be 2.
