Correct EVAP VSV Function?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Npax2, Jan 15, 2017.
  1. Jan 15, 2017 at 8:44 PM
    Npax2
    Npax2 [OP] Well-Known Member
    Nick
    Oregon
    97 Tacoma 2.7l Single Cab
    Does anyone know how this vsv is supposed to act? I have a P0441 evap code and vacuum checked my evap vsv and charcoal canister. Canister tested bad as it would not hold vacuum when all ports plugged (I actually found the Crack in it). I have 2 evap VSV's and ran 12v to each of them with a vacuum hooked to them. One of them opens and expels the vacuum immediately, while the other opens and releases the vacuum at about 1psi every 2 seconds. The VSV for the EGR valve releases immediately, so I'm leaning towards the immediate release being the desired action.
  2. Jan 15, 2017 at 11:45 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    There either open or closed with power. Not doing both. Sounds like its bad.
  3. Jan 16, 2017 at 12:21 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Agreed. Either open or closed.
    I just went through checking all mine after similar codes. My canister is fairly new, but one of the two VSVs under the hood (VSV for evap if I remember correctly) was stuck. New Denso VSV and gas cap and the codes are gone. The FSM has the testing procedures for the VSVs.
  4. Jan 16, 2017 at 11:58 AM
    pheding
    pheding Well-Known Member
    Wisconsin
    2001 Yoda Tankoda 2.7L I4 4x4
    Had P0441 about a month ago. Found a Dorman part on Amazon that was the exact same. Switched em out . No CEL light since.
  5. Jan 16, 2017 at 12:28 PM
    Npax2
    Nick
    Oregon
    Awesome, that's what I had figured so I put the open/closed one on. No CEL after 50-60 miles and 2 computer cycles so far :fingerscrossed:
  6. Jan 17, 2017 at 9:39 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I wonder what kinds of emission problems will crop up on these newer vehicles with no gas cap in 10 years?
