Correct fluid for power steering on 1998 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by mark5634, Oct 1, 2011.
  1. Oct 1, 2011 at 9:17 PM
    mark5634
    mark5634 [OP] New Member
    98 Tacoma Xtra Cab
    I had my 1998 Tacoma 2wd Xtra Cab pickup power steering system flushed and serviced at my local Toyota dealer about a year ago and just discovered today that the fluid they refilled it with is Blue Mountain professional brand power steering fluid. It does not say that it is ATF type Dexron II or III compliant. It says only that it mixes with all other power steering fluids. The owner's manual to my truck and the power steering cap says to use Automatic Transmission Fluid Type Dexron II or III to refill the power steering system. Does anybody know if the Blue Mountain power steering fluid is harmful to the Tacoma power steering system?
  2. Oct 7, 2011 at 7:05 AM
    00PreRunner
    00PreRunner Well-Known Member
    Jackson, MS
    '05 DCSB 4x4
    2005 DCSB, 4x4, Auto. more to come...
    Never hear of it but I run Lucas Power steering and have never had a problem out of it.
    burntkat likes this.
  3. Oct 7, 2011 at 2:42 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Use tranny fluid. NOTHING ELSE
  4. Oct 7, 2011 at 11:08 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    burntkat and heartbreaker like this.
  5. Oct 8, 2011 at 6:30 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Our tacos call for Dex III or equivalent ATF.
  6. Oct 8, 2011 at 7:01 AM
    Roldaddy
    Roldaddy Pilot of The Colonel
    Wise, VA
    98 Tacoma SR5
    2 inch lift, alloy wheels, bed cover, bf Goodrich 33x10 1/2 tires, 2k watt stereo
    always used dot 3.
  7. Oct 8, 2011 at 8:26 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I use PS fluid...
    PS fluid will not F up your PS pump, if you mix the 2 it can, thats where people have problems, when working on Tacomas I see about 50% of them running clear fluid (PS fluid). When mixing the two they tend to foam and thats where you have loss of hydraulic function..
    The big difference is PS fluis is not flammable, trans fluid is, so in the event of a front end collision it could start a fire, however since an automatic has a heat exchanger in the radiator it will leak trnas fluid anyway, so...
    My recomendation is just to use whats in there, if its red use dextron, if clear use PS fluid.
    In my personal truck I always ran PS fluid and had over 180,000 miles with no problems whatosever.
    Just dont mix the fluids is the most important thing..they will both work just fine, I know this from over 20 years of first hand experience..
    heartbreaker likes this.
  8. Oct 8, 2011 at 1:10 PM
    TacoMX
    Jonathan
    Deltona, Florida
    All I know is that the PS resi cap says to use Dextron III ATF...so I do. It had regular PS fluid in it, so I did a good flush and replaced it with Dex III.
  9. Oct 8, 2011 at 1:44 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    I put Redline MT90 in my old Tacoma
    the guy who bought it hasn't had a problem since then
    (he called me a couple days ago asking about how to do a BPV flip)
  10. Oct 8, 2011 at 3:10 PM
    tnt136913
    tnt136913 Member
    my 03 pre runner has brake fluid from the factory , yea i sh-t to,, but it does make sense
  11. Oct 8, 2011 at 4:06 PM
    Speed Freek
    Yeah thats fine they do the same thing, just as long as you flushed it like you said its totally fine.
    Power steering fluid not brake fluid.
  12. Oct 9, 2011 at 6:10 AM
    ERG80
    ERG80 Newb
    TN
    1997 T100 & 1996 FZJ80
    What kind of PS fluid are you using?
    I put Mobil DTE light hydraulic fluid in my Cruiser when i installed a PS cooler. Been running it for years. It really quieted and smoothed the steering pump.
  13. Oct 16, 2011 at 7:21 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Just curious, what is the difference between the clear an red ps fluid? An anyone think Toyota ws trans fluid would work good in there?
  14. Oct 16, 2011 at 11:31 AM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Amsoil DEX III
  15. Oct 16, 2011 at 6:58 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    Is Dex/Marc an Dex III the same thing? Just flushed it an put Dex/Marc in an seen a little foaming. It had the red stuff in it from factory an the cap said Dextron. I also bought a small trans cooler Im going to install as a PS cooler. Any idea's on good locations an good ways to mount it?
  16. Oct 16, 2011 at 7:54 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I dont think its the same thing, but I think its close enough. After flushing your PS system its okay to see a bit of foam, its just air in the system that needs to be bled out.
  17. Oct 16, 2011 at 8:00 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    Is there a way to bleed it or will it just bleed itself in time?
  18. Oct 16, 2011 at 8:03 PM
    TacoMX
    Jonathan
    Deltona, Florida
    jack up your front end w/ the tires off the ground and remove the PS resi cap. Turn the wheels back and forth (avoiding full lock) about 20 times. Let it sit off for about 30 mins then let it idle and check for foam/bubbles. Repeat till no foam/bubbles.
    edit:
    Is it more foamy or bubbles? Foam may be bad, but a little bit of aeration is from air in the system.
  19. Oct 17, 2011 at 4:40 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    It was only foamy/bubbly ( kinda in between ) about half way down. I pumped it out an refilled. Did the back an forth with the wheels an it was good. Thanks
  20. Oct 17, 2011 at 3:35 PM
    TacoMX
    Jonathan
    Deltona, Florida
    good to hear!
