Correct Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dalton092, Mar 16, 2016.
  1. Mar 16, 2016 at 7:35 PM
    Dalton092
    Dalton092 [OP] Well-Known Member
    Just curious, getting ready to change gear oil in my rear diff, and Ive been reading and from what I understand its only the trd sports that are suppose to use the lsd oil, yet my 2008 base sr5 has a sticker on the diff that says lsd oil only. Not wanting to put the wrong stuff in it and cause problems, so any help is appreciated here fellas!!
  2. Mar 16, 2016 at 8:18 PM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Personally, if that sticker was on there, I would put the oil with the LSD friction modifier in it just in case. It won't do any harm if you don't have an LSD. Who knows if it was something special for a regional distributor or of that is the axle that even came with the truck(unless you bought it new).
  3. Mar 16, 2016 at 8:44 PM
    Bishop84
    Bishop84 Well-Known Member
    Likely that you have it, but an easy way to check is to jack the rear wheels in the air and see if both wheels spin together in the same direction. If they rotated opposite its a standard diff, together it has an LSD.
    I'd just buy the additive if you already have the gear oil, the Toyota stuff is fairly expensive.
  4. Mar 16, 2016 at 10:16 PM
    Dalton092
    Well I guess I just got lucky and snagged one with the LSD, I'll try the jacking it up, but if it dont hurt to use the modifier anyway I'll just put it in anyhow.
  5. Mar 17, 2016 at 3:17 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    The sticker is there to eliminate confusion, let it do its job.
