Correct Offset
Discussion in 'Wheels & Tires' started by Toyota Truck, May 5, 2009.
  1. May 5, 2009 at 6:58 AM
    Toyota Truck
    Toyota Truck [OP] Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Hello TW, I plan on buying these wheels their Rebel Racing Sahara Wheels (Matte Black). The size is 16x8, bolt pattern is 6-139.7mm, and the offset is 0 the tire i will be runnin is 265/75/16 BFG KM2. Is the offset correct or will I have rubbing issues if the offset is wrong what is the right offset, cause I dont want to use spacers I also plan on getting a 3 inch lift. (I drive a 08 Prerunner if it matters)
  2. May 5, 2009 at 7:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm pretty sure those are fine- A 0 offset means those rims have a 4 inch back space...and 4.5 is the max backspace possible with our trucks.
    But let a few other folks chime in before you click order.
  3. May 5, 2009 at 7:05 AM
    fixedforbroke
    fixedforbroke Well-Known Member
    St. Simons Island
    06 PreRunner SR5 White as Snow
    Stock the way god made her. (FOR NOW)
    X2
    P.S. Those wheels will look sick, tell me how you like them
  4. May 6, 2009 at 12:00 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Can any one else give me some advice?
  5. May 6, 2009 at 12:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My rims are 4.5 BS and 0 offset.
  6. May 6, 2009 at 12:07 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Do you having any rubbing issues like on the "A" arms?
  7. Mar 16, 2010 at 7:31 PM
    SoCal Taco
    SoCal Taco Member
    DID you end up getting these wheels with the 265's and a 3" spacer?? I have an 07 tacoma and I just ordered these 16" wheels, goodyear duratrac 265/75/16, and a 3" spacer.
    I hope it all fits and the backspacing is correct.
  8. Mar 16, 2010 at 7:36 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    should fit fine
  9. Mar 16, 2010 at 7:37 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    welcome to tw and yes it will work! ^^^^^^^
  10. Mar 16, 2010 at 7:39 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    sup newbies, have fun noticing the thread revival and the new, relevant question? :p jk!!!
  11. Mar 16, 2010 at 7:43 PM
    TacoSupreem
    Hayden
    Kentucky
    :p
  12. Mar 16, 2010 at 8:13 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Was reading through some wheel threads and just read that 4.5" backspace was the most you could go on our trucks
    I just ordered 18 x 9 12 offset 5.5 backspace for my pre-runner
    Am I missing something here?
    My stock wheels are 5.5 backspace
    Thanks for any info...
  13. Mar 16, 2010 at 9:13 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you matched your stock backspace which is fine if you plan to run stock tire size...
    if you plan to upsize your tires, that backspace won't work...
    you want the wheels to stick out by about an inch or so to clear the stock UCA and truck frame...
  14. Mar 17, 2010 at 1:07 PM
    TacoSupreem
    Hayden
    Kentucky
    My wheels are 5.71bs and+18 os and I have no rubbing and larger than stock tires
