Correct oil weight
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyota 4 ever, Apr 20, 2011.
  1. Apr 20, 2011 at 6:51 PM
    Toyota 4 ever
    Toyota 4 ever [OP] Member
    Gallatin, tn
    98 sr5 2RZ
    Guy before me put cold air intake? Wish it was factory.
    Hello everyone, Glad to be on here! I have a 1998 sr5 tacoma 2RZ with 323,200 miles on it currently and still going strong. All I replaced was a cracked exhaust manifold. My question is what is the correct or recommended weight? I've been using pennzoil 15w-40 weight. Any advice? Thanks.
  2. Apr 20, 2011 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    10w-30
  3. Apr 21, 2011 at 5:10 PM
    mike sacc
    mike sacc Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    15 40 is generaly used for deisel engines. the owners man. says 5 30 for my 2.7 but if thats what got u 300000 plus why change
  4. Apr 21, 2011 at 5:15 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I run 5-30 its what the manual says.
  5. Apr 22, 2011 at 11:36 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
  6. Apr 22, 2011 at 11:50 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I am willing to bet if you go back to the OEM weight you will probably burn some oil. I have a 01 honda with 265,000 that used 5w-30 from the factory but now I run 10w-40 to keep it from burning about half a qt. every 5,000.
  7. Apr 22, 2011 at 12:16 PM
    JRockTaco
    JRockTaco Just some guy
    Sandy Eggo, CA
    '04 4x4 V6 Manual TRD Ext. Cab Lunar Mist
    Donahoe 2.5" coilovers, Camburg UCA, Deaver leaf springs, Bilstein 5100 rear shocks, Elite front plate bumper, Demello Offroad rear bumper & rock sliders, K&N FIPK, Line-X, BAKFlip G2
    I run 5w-30 Mobil 1 full synthetic, have been using it for about 2 years with no problems. Just don't overfill it, my truck seems to shift funky when you overfill the oil. I have a manual tranny, not sure if that makes any difference.
  8. Apr 22, 2011 at 12:18 PM
    JRockTaco
    Sandy Eggo, CA
    the owners manual says to use 5w-30 but have been told that you can run a little heavier oil in older engines to keep it from wearing down too fast. But wouldn't switching to a full synth do that anyways?
  9. Apr 22, 2011 at 1:43 PM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    5w30HM or just 10w30. switching to synth at that mileage might make it burn oil.
  10. Apr 22, 2011 at 6:44 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    5-30. Do an oil analysis to check the health of your engine.
    My buddies '04 3.4 burns no oil with 250k miles. He runs, and always has run, Mobil1 5-30 with drains in the 12-15k range. That truck runs as smooth as ever. No reason to change viscosity unless something is wrong. Again, do an oil analysis.
