Correct rotopax mount for Prinsu load panels ??
Discussion in 'PrInSu Design Studio' started by Maximilian, Dec 3, 2018.
  1. Dec 3, 2018 at 7:16 AM
    Maximilian
    Maximilian [OP] Well-Known Member
    North Dallas, Texas
    2014 Spruce Mica TRD Sport 4x4
    What are you guys using to mount your rotopax?
    I have this mount.
    With all the holes this load panel has, non of them line up right.
    I can get three of them to line up more towards the center, but want it to the side
    What are you guys doing to get the the mounts to attach?
    I was just gonna drill some more holes if nothing suggested.
  2. Dec 6, 2018 at 3:19 PM
    Dvogt86
    Dvogt86 Member
    Devon
    2017 Toyota Tacoma DCSB TRD Off-road (Cement)
    Prinsu Cabrac Caliraised molle bed panels
    Take the backing plate off. You will find that you have more options once you do that. Mine are off to the side. Also check out Justin B. McBride’s YouTube channel. He recently did an install video. https://youtu.be/dJexQbknQ5Q
    Do you have any rattle issues with your load panels?
  3. Dec 6, 2018 at 3:36 PM
    Maximilian
    North Dallas, Texas
    Thank you Dvogt86,
    My mount was the free one they sent. Its the FuelpaX Deluxe Pack Mount. Its all one piece.
    So I ordered the DLX Pack Mount.
    So I will be able to take it apart and attach the way you suggested. Should be here tomorrow.
    Yes, my load panels do rattle, even with the spacers they sent.
    It's not horrible, but I hear it often.
    I take it yours do as well?
    I thought about wedging some foam tape in there to help.
  4. Dec 6, 2018 at 3:51 PM
    Dvogt86
    Dvogt86 Member
    Devon
    I might try loosening one bar, clamp it all together and then tighten it up and see if that helps.
  5. Dec 7, 2018 at 8:22 PM
    Dvogt86
    Dvogt86 Member
    Devon
    I don’t have rattle anymore. Here is what you can do. Make sure one bar has the screws tight against the opening towards the side of the load panel. Then loosen the other bar completely. Clamp the bars together (not where there is a void), then tighten the screws on the bar. You will get a little bit of side to side movement, but the highway flutter is gone.
    cuda2k likes this.
  6. Dec 30, 2019 at 10:20 AM
    spitfirestu
    spitfirestu Well-Known Member
    The Orange Curtain
    2017 Tacoma TRD OR DCLB
    2.5 King shock front leveling kit, 17" KMC wheels, 285/70/17 K02s, Aluminum front bumper, Snugtop shell, Rigid 30" LED light bar, SPC UCAs, Bilstein 5100s rear
    Sorry to resurrect this thread, but do you need those wide and flat load panels to mount the Rotopax base? Or can you use angle bar aluminum to bolt on a base instead, the way folks have put their Maxtrax on? Thanks!
    microsnook likes this.
  7. Mar 26, 2020 at 11:52 AM
    Samdfunkymonkey
    Samdfunkymonkey Active Member
    Sam
    2012 Trd long bed
    2” lift, 31” bfg ko2s, relentless front bumper with Baja fogs, smittybilt winch.
  8. Apr 25, 2020 at 7:31 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Bump ^ still wondering the same thing lol
  9. Oct 23, 2020 at 3:22 PM
    Deadbird Society
    Deadbird Society Member
    Paul
    Richmond VA
    2017 TRD Sport
    TRD rims & grille, Yakima & Prinsu racks, Baja Designs (up front and out back), Morimoto XB LEDs
  10. Apr 17, 2021 at 5:12 PM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Anyone mount a 4 gallon rotopax on their Prinsu without the load panels? Can’t find any images or info on which attachments to purchase for the rotopaxs
  11. Nov 17, 2021 at 7:49 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Thanks for this suggestion, did this when I installed my panels last night. First drive silent, or at least as silent as the rack was before the panels.
