CORRECT STREET TIRE PRESSURE
Discussion in 'Hilux' started by JAMES399, Apr 8, 2017.
  1. Apr 8, 2017 at 8:45 AM
    JAMES399
    JAMES399 [OP] EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    I have a 2003 HILUX 4x4 DCSB. The truck has 265-70R16 tires. I know this will sound like a nubee question but what is the recommended tire pressure to run on the street ?? My Hilux does not have a sticker on any of the doors with recommended pressures and neither does the owner's manual. I am running 30 psi, but I saw a post where someone said 40 psi was good for the street. Am I good at 30 psi ??
    - JAMES
  2. Apr 8, 2017 at 8:54 AM
    Bishop84
    Bishop84 Well-Known Member
    Play with it, but 30psi is ideal, the older lighter models benefit from lower pressures.
    JAMES399[OP] likes this.
  3. Apr 30, 2017 at 7:48 AM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    You the chalk test to dial in the correct tire pressure, it's easy and it works
