correct tire pressue confused
Discussion in 'Wheels & Tires' started by Alan53, Apr 28, 2023.
  1. Apr 28, 2023 at 11:57 AM
    Alan53
    Alan53 [OP] Active Member
    Alan
    Brimfield Ma
    2012 tacoma Baja
    I have a 2012Tacoma Baja edidition with the bead locked rims I just had some new tires put on cooper AT3's I asked the guy what tire pressure did he use he told me the door sticker one which says 48 pounds its a over lay sticker that was put on after. thatToyota sent the OG owner a while back now is it
    right to have them that inflated just seems strange
  2. Apr 28, 2023 at 12:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    IIRC, the Baja Edition came with LT tires.
    If you run less than 46-48 psi, the TPMS light may come on.
    If you put on different type, such as P rated, you will need to adjust accordingly.
    You can reset the TPMS set pressure. It’s in the owners manual.
    tcjacado and HondaGM like this.
  3. Apr 28, 2023 at 12:27 PM
    Alan53
    Alan
    Brimfield Ma
    2012 tacoma Baja
    so is the pressure safe that he used in the Cooper AT3 tires or should I lower them
    HondaGM likes this.
  4. Apr 28, 2023 at 12:32 PM
    TnShooter
    Deogee
    STOCK
    The maximum cold inflation pressure is on the tire itself.
    If the pressures in the tire now is below the listed max cold pressure, you should be fine.
    I can not say what the best pressure to run would be, that depends on the load range the tire is.
    And I don’t know offhand what load ranges are available for the the Cooper AT3 tires.
    If you tell us the load range and ply, we might be able to further help.
    All this is on the tire sidewall as well.
    tcjacado, HondaGM and 3JOH22A like this.
  5. Apr 28, 2023 at 12:46 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That seems like way too much PSI. The minute you get rid of OE tires your proper PSI changes. If you have typical C rated tires 35 is a good starting point but you should google " tire chalk test " that is really the easiest DIY method to find the right PSI for your truck and your tires.
    HondaGM likes this.
  6. Apr 28, 2023 at 12:49 PM
    Alan53
    Alan
    Brimfield Ma
    2012 tacoma Baja
    I looked on tire cant really find what you were looking for some print is micro small and at my age its very hard to see lol but these are the tires 265x70x16 OWL https://coopertire.com/en-us/find-tires/all-tires/discoverer-at3-4s
    HondaGM likes this.
  7. Apr 28, 2023 at 1:04 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    HondaGM likes this.
  8. Apr 28, 2023 at 1:17 PM
    Alan53
    Alan
    Brimfield Ma
    2012 tacoma Baja
    so you think I should lowerthe pressure since they are notLT tires
    HondaGM likes this.
  9. Apr 28, 2023 at 8:25 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I run 35 front 30 rear, your tire light won’t come on. Our trucks are so light in the back end that 48 lbs will make it ride terrible, like a rock.
    Unless your towing a trailer or have 600lbs in the bed, then up the air pressure.
    HondaGM likes this.
  10. Apr 28, 2023 at 8:36 PM
    Pinatacoma
    Pinatacoma Well-Known Member
    Vancouver Island, BC
    2020 ACOR
  11. Apr 28, 2023 at 8:37 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Std or P rated aren’t load C tires, they are like 2ply.
    C are LT tires 6 ply rated for loads, towing.
  12. Apr 28, 2023 at 10:45 PM
    TnShooter
    Deogee
    STOCK
    I don’t man. This thread says other wise.
    See post #17. The Baja comes set at 46 psi.
    Unless you reset the learned psi, the light will come on.
    https://www.tacomaworld.com/threads/baja-tx-tire-pressure.291846/
    They made the cooper tires OP has in different load ranges.
    We still can’t really “help”.
    tcjacado and Bivouac like this.
  13. Apr 29, 2023 at 12:35 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    On my 1st gen, I'm at 25F and 24R on HOT pressures on C load KO2. Verified with the chalk test when I first installed them. I'm about 25k miles in and the wear is flat across the face and very even.
  14. Apr 29, 2023 at 12:48 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    it depends how you use the Truck.
    When i worked the truck was loaded heavy and towed another 2000 pounds often.
    I ran 60 psi in the rear and 40 psi in the front through a few sets of tires.
    DavesTaco68 and tcjacado like this.
  15. Apr 29, 2023 at 1:00 AM
    tcjacado
    tcjacado Well-Known Member
    The higher the pressure = better gas mileage but typically horrible tire wear.
    I would start at 38 on pressure and check the tire wear... or do a chalk test as mentioned in previous posts.
  16. Apr 29, 2023 at 2:28 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Went to tire rack and if you have the size stated only come in SL so here are the specs so max 44psi and I would run at 35 all around then watch tread wear.
    (Note: use your phone and take a pic of sidewall then enlarge pic to read)
    SPECS FOR: COOPER DISCOVERER AT3 4S
    View Specs for All Sizes
  17. Apr 29, 2023 at 6:32 AM
    Alan53
    Alan
    Brimfield Ma
    2012 tacoma Baja
    Thanks a million guys for all the info much appreciated I am going to drop them to 35psi I do have a cap on the bed and 2 tool boxes in back so will watch tires after i Drop them next time I go to Wal Mart or some other place with a tarred parking lot will do the chalk test my drive way is gravel oh by the way I am 70 yearsold but I still enjoy trucks lol
    tcjacado likes this.
  18. Apr 29, 2023 at 9:34 AM
    tcjacado
    Where are you located? There may be a few members in your area willing to help you :hattip:
  19. Apr 29, 2023 at 9:59 AM
    Alan53
    Alan
    Brimfield Ma
    2012 tacoma Baja
    I am located in Mass. Brimfield right by palmer as soon as the rain lets up I am lowering to 35 PSI and will check Tirewear My next Project is to try to get the rear sag out of bed since i have a cap on it I just ordered some 5100's the OG owner took the original shocks out the ones with the canister attached put in some other shocks no name then I may have to do a single AAL also Truck is in great shape for a 2012 I get a lot of compliments on it for the record LOl my first Toy was a 78 FJ40 landcruiser had a warn winch in front an back with 11.50 tires was a great truck but some body liked it more an got stolen while christmas shopping my next toy was a 1987 Toy 4x4 truck was a great truck did some good off roading with that one till the frame rotted out after them a fewFords now back to a Tacoma I will say this is prob the most comfy truck I have driven all my trucks have been 4x4 since i live on a mountain lol with out 4x4 you walk the road home
  20. Apr 29, 2023 at 10:47 AM
    tcjacado
    https://www.tacomaworld.com/threads/western-massachusetts-tacomas.168431/
    Ask here in this thread, you should be steered in the right direction. There are a lot of good people in the north east section ;)
