Correlation between “diff howl” and air dam removal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Apr 16, 2023.
  1. Apr 16, 2023 at 5:06 AM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    Just curious if anyone experiencing increased noise from undercarriage or “diff howl” has also removed the air dam from the front end? Wonder if that has a direct affect on the air flow and increased noise?
    Has anyone reinstalled the dam and noticed decreased noise?
    Thinking about trying this to see if it makes any difference.
  2. Apr 16, 2023 at 5:07 AM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    When I think of diff howl - it's a mechanical noise internal to the diff that would present itself if the vehicle was in the air, not moving, but the wheels were rotating.
    Wind noise is something completely different, obviously.
    I guess my point is that diff howl, in my opinion, is not and can not be caused by wind. If you are getting wind noise, you are not necessarily getting diff howl, and vice versa (although the two could exist at the same time, simultaneously).
  3. Apr 16, 2023 at 5:30 AM
    joncure
    VA
    Understood and agree, wind noise and mechanical noise are different and not caused by the other.
    Just wondering if some/most/all noise coming from under truck while moving increases with air dam removal?
    Also wonder if owners automatically associate any noise at speed with diff howl. Maybe it’s air flow noise after air dam taken off?
    Like you said, putting truck in air with wheels turning would prove diff howl noise.
    deaps likes this.
  4. Apr 16, 2023 at 5:31 AM
    deaps
    2023 TRD OR
    Yeah you definitely make a good point.
  5. Apr 16, 2023 at 5:32 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    fwiw, i have a trd sport with an air dam and what i believe is diff noise. :notsure:
    hiPSI likes this.
  6. Apr 16, 2023 at 5:35 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Trd offroad, no air dam, no diff howl.
    Tocamo likes this.
  7. Apr 16, 2023 at 5:37 AM
    joncure
    VA
    Alright, doesn’t seem to be any correlation. Thanks.
  8. Apr 16, 2023 at 5:40 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Way too early for me to really think about this! If there is any correlation at all, I would think a mechanical noise like a rear differential howl would be more noticeable with the air dam on and less noticeable with the air dam removed.
    Is that the correlation you are trying to get at, a simple masking of a mechanical sound by a louder air sound?
    Travlr likes this.
  9. Apr 16, 2023 at 6:07 AM
    joncure
    VA
    Basically Buck. You just worded it differently. Presence of air dam may mask other noises by reducing air flow noise.
    Guess I’m just wondering how much air dam affects any or all noise coming from under truck while moving. And, do some of us confuse air flow noise with actual diff howl?
    As deaps stated earlier, the best way to find out is to put truck in air and get wheels turning. That will prove a diff howl vs air noise.
  10. Apr 16, 2023 at 6:12 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The rear diff noise some have is... The noise is caused by resonance, meaning the gear mesh and the bearing and the axle and housing and the springs, at a certain speed, will make a noise. I had it on my 17 TRD sport with airdam. I don't have it on my 21 TRD off road. Wind noise has nothing to do with it.
  11. Apr 16, 2023 at 6:17 AM
    joncure
    VA
    I understand wind has nothing to do with actual diff howl. I am not confused by the difference in wind flow at higher speeds vs the sound of mechanically caused resonance.
    My main point/question is paragraph 2 of my last post.
  12. Apr 16, 2023 at 6:19 AM
    joncure
    VA
    Or maybe I am confused!?!?:annoyed:
  13. Apr 16, 2023 at 6:21 AM
    Firn
    Firn Well-Known Member
    White OR
    I have very slight diff howl in my MT truck, I can say for a fact it is direct correlated to rpm and engine load, not airflow
    joncure[QUOTED][OP] likes this.
  14. Apr 16, 2023 at 6:22 AM
    joncure
    VA
    Wish I had a lift, or access to one and put this post to bed!
  15. Apr 16, 2023 at 6:23 AM
    Mutzdude
    Mutzdude Well-Known Member
    Long Island, NY
    ‘21 TRDOR DCSB 6MT - Army Green
    Interesting hypothesis. May I add another? There is certainly a strong correlation between loud music and diff howl. I only hear my diff when the volume is low or off.
    Kolache007 and hiPSI like this.
  16. Apr 16, 2023 at 6:24 AM
    joncure
    VA
    Amen!!!
  17. Apr 16, 2023 at 6:29 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    There’s a hole in each lower control arm that can howl. Tape it up and see.
    hiPSI likes this.
  18. Apr 16, 2023 at 6:32 AM
    Buck Henry
  19. Apr 16, 2023 at 6:35 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    You are fast on the meme creations Buck!
  20. Apr 16, 2023 at 6:38 AM
    Buck Henry
    Thanks, but I stole it. I'm just damn good at googling for stuff. :)
    Squirt and TacoTime55[QUOTED] like this.
