Corresponding part numbers for 3rd gen leaf springs to 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Not a golfer, Jun 19, 2022.
  1. Jul 6, 2022 at 4:48 AM
    Frez1812
    Frez1812 Well-Known Member
    2012 Tacoma 4.0
    Thanks, hoping this guy doesn’t want a fortune for the leafs.
  2. Jul 6, 2022 at 4:58 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    You see that positive arc in the spring pack? That's the last time that you will see it. I swapped that same suspension onto my '15 Taco, within 6 months the springs were flat. Now 18 months later they are sagged. The truck gets very little use as a "truck", I will load the utility trailer and use the 4runner to pull it when there is heavy hauling to do.
  3. Jul 6, 2022 at 5:08 AM
    Frez1812
    2012 Tacoma 4.0
    You telling me those springs off the 2022 are worse then what’s on my 2012?
  4. Jul 6, 2022 at 5:59 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    @Frez1812 No, they arent...Tacoma rear springs, ALL models, are just light duty springs and sag easily...he is being amusing, but your OEM springs held up for however long, these will also under the same use conditions.
    2ndhandTacoman likes this.
  5. Jul 7, 2022 at 11:29 AM
    2ndhandTacoman
    Walter
    Maryland
    Not at first, but they won't last vey long. The original ones on my '15 were so badly sagged the axle was almost hitting the bump stop, so the take-off spings were a huge improvement for not a lot of $$. I just expected them to last longer then 1 1/2 years with minimal usage.
  6. Jul 7, 2022 at 11:33 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I have a set of 3rd gen take-offs from my 2021 with 800 miles on em. Looking for $100 w/ local pickup in AZ if anyone is interested.
    FWIW the 4-leaf 3g packs are a big upgrade to any 2g guys still running the 3-leaf packs.
    kevinRR likes this.
  7. Jul 7, 2022 at 6:30 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    If you want to use your truck for hauling around stuff it would be better for you to get aftermarket heavy duty leaf springs. They won't sag as much and are much stiffer.
  8. Jul 17, 2022 at 8:41 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    I broke a leaf in my passenger side leaf pack recently and have found a set of 3rd gen takeoffs with an aal already installed. My question is these 3rd gen packs don’t have any hardware, can I use my existing ubolts and shackles or do I need to purchase something else? Hoping someone can steer me in the right direction.
  9. Jul 18, 2022 at 7:58 AM
    MSgt O
    2013 Tacoma
    @Steelhead Bum U bolts are a one time use thing, or theyre "supposed" to be..you can reuse them, but i wouldnt. Shackles, yes you can reuse those.
    Steelhead Bum likes this.
  10. Aug 1, 2022 at 11:53 AM
    Steelhead Bum
    Mitchell
    Eastern WA
    Anybody know the dimensions of the oem u-bolts or can anybody point me in the right direction to find these specs? I am going to get a custom set made locally from a highly reputable spring shop for the new 3rd gen plus aal setup going on the truck. The shop wants to know the oem ubolt dimensions then compare difference in height of oem pack and new pack to calculate the increased length needed for the bolt. Sound right? These are the dimensions I came up with for the oem u-bolts.
    diameter at threads: .562” or 9/16
    OD height: 7”
    OD width: 3.5”
    ID width: 2.4325” or 2-7/16”
    Oem 3+1 leaf pack height: 2”
    U-bolt style: square
    Besides for u-bolts what else needs replaced? How about the front and rear mounting bolts? Not sure of the correct term for them.
    And finally if anybody can point me in the direction of the torque specs it would be greatly appreciated. I’m hoping to diy install these this weekend.
  11. Aug 1, 2022 at 12:41 PM
    MSgt O
    2013 Tacoma
    only thing i can find:
    These SQUARE RADIUS Grade 5 U-bolts are available in 6.75", 7.75", 8.5" and 9.5" lengths (measured from the inside of the bend radius to the end of the threaded leg).
    They will fit Tacoma 4x4 / PreRunner, Tundra, and many other applications that require a 9/16" square radius U-bolt with a 2-9/16" ID. These are custom made in the USA to fit our Toyota applications. Note: These bolts are for standard U-bolt configurations. Do not use with U-bolt flip kits!
    Note: As a general guideline, these are the bolt lengths we recommended for each application:
    • 6.75” – 1986-1995 Pickup/4Runner, 1995-2004 Tacoma
    • 7.75” - 2005+ Tacoma
    • 8.50” - 1999-2006 Tundra
    • 9.50” - 2007+ Tundra
    And if you're swapping springs, its always a good idea to replace any hardware that you can.
    from another post about springs: Spec is 89ft-lbs for the spring eye and shackle bolts. Leave them loose until everything is assembled and the truck is sitting on the suspension to prevent excess torsion of the rubber bushings in the normal position, which will accelerate bushing failure. Unless you are using polyurethane bushings, in which case it doesn't matter.
    reallifedog and Steelhead Bum like this.
  12. Aug 1, 2022 at 12:49 PM
    Steelhead Bum
    Mitchell
    Eastern WA
    Thank you. I’ll remeasure the overall height of the u-bolt to double check my measurements. It appears to be the only one that’s significantly off in terms of the dimensions provided. I’ll inquire about replacing spring eye bolts while I’m there.
  13. Aug 2, 2022 at 7:57 AM
    MSgt O
    2013 Tacoma
    Good Luck!!
  14. Jun 11, 2024 at 8:33 AM
    Crash709
    Crash709 Member
    Mark
    2012 Toyota Tacoma 4 Cyl 4x4
    How did the custom spring packs work out?
  15. Sep 18, 2024 at 7:55 PM
    #35
    VikingTrad3r
    VikingTrad3r Well-Known Member
    "contractor model" white with black fenders
    My kit from Standens in Calgary ive just discovered has a broken leaf. I will see if they warranty but i highly doubt it. its been 10years.
  16. Oct 13, 2024 at 12:58 AM
    #36
    Frez1812
    2012 Tacoma 4.0
    Is the ext cab and double cab leaf springs all the same? Are they the same length?
  17. Oct 15, 2024 at 8:11 PM
    #37
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Just to verify do the OEM 3rd gen leafs sit .5-1" higher then 2nd Gen?
