corroded aluminum rims leak air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QChawks, Dec 10, 2018.
  1. Dec 10, 2018 at 9:08 AM
    QChawks
    QChawks [OP] Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I have a rim that is corroding on 09 so I have to add air every couple days here in the cold midwest. Last year when I took to Discount Tire they were nice enough to clean the rim and that lasted about 6-7 weeks until the issue came back.
    Anyone fix this yourself?
    I'm thinking about taking the wheel off, deflating completely to see if I can break the seal enough to clean the rim edge.
  2. Dec 10, 2018 at 9:15 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I had that problem with another set of alloy wheels. Salt will corrode anything & these wheels were pretty far gone. I ended up getting a deal on refinishing (powder coated). My tire guy uses just the bare minimum of bead sealer when installing the tires. He said it holds salt & moisture that causes the corrosion. He also said to stay away from caustic based car wash soaps. Real PITA when it gets real cold.
  3. Dec 10, 2018 at 9:20 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Buy new wheels. Boom problem solved. Plus with how many people get aftermarket wheels now stock wheels are EVERYWHERE for like 200$ per set of 4. Just look around online
    Norton likes this.
  4. Dec 10, 2018 at 9:24 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ why bother with trying too fix wheels that are no good.
    Norton and Muddinfun like this.
