Corrosion near battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19OR, Feb 25, 2022.
  1. Feb 25, 2022 at 2:34 PM
    19OR
    19OR [OP] Well-Known Member
    Jay
    2019 TRD Off Road Magnetic Gray
    I’m about to sand and paint this but is there a reason this happened? Is it something I should look into more?03F58F45-FEF2-4C04-B4B7-040578242F93.jpg
  2. Feb 25, 2022 at 2:45 PM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    Looks pretty bad. I’d see if the dealer would replace it
  3. Feb 25, 2022 at 2:45 PM
    xndak
    xndak Well-Known Member
    2023 Off Road
    Wet it, apply baking soda- spray off, sand and paint. Apply some battery post corrosion protector or Vaseline to those areas + posts and cables and yet it will still probably come back after some time.
  4. Feb 25, 2022 at 2:47 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Wetcell batteries constantly offgas acid fumes & hydrogen. The hydrogen is why you never smoke or cause sparks around them (hence the "ground a jumper cable away" from them). They also can spill the acid out through the vent. Mine did when off-roading.
    That acid will corrode metals.
    Also, due to this venting of gasses, you need to maintain the terminals -and- the water level. Keep the terminals clean of the corrosion caused by the gasses & spilled acid. Top up the cells with distilled water when needed (careful not to over-fill).
    3JOH22A and Sterling_vH111 like this.
  5. Feb 25, 2022 at 2:52 PM
    TartanEagle
    '17 ACLB 4x4 MT
    Have you had much experience with using Vaseline? I have used different products and some (engine oil in particular) caused an insulating effect. The oil actually isolated the clamp from the terminal and interrupted the connection. Couldn't start the engine until I cleaned it all off. Just curious if Vaseline could do that.
    Edit: Sheesh, I misread your post. I was thinking you had recommended to coat the battery post with Vaseline. Now I see you advised to coat the corroded areas with it, and not the terminal posts.
    Skydvrr likes this.
  6. Feb 25, 2022 at 2:52 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    See below
    Big tall dave likes this.
  7. Feb 25, 2022 at 2:58 PM
    eurowner
    eurowner Duke Sky
    Scoty
    100% normal.
    19OR[OP] likes this.
  8. Feb 25, 2022 at 2:58 PM
    xndak
    2023 Off Road
    I have always used a spray on protectant - just read about the vaseline use. Spray on will be much easier and less messy to apply and it sorta drys to touch
    TartanEagle[QUOTED] likes this.
  9. Feb 25, 2022 at 2:59 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    This ^
    Mine look much worse. I need to get an AGM battery.
  10. Feb 25, 2022 at 3:02 PM
    TartanEagle
    '17 ACLB 4x4 MT
    Yep! That was my plan of attack too. But my stock batt is still performing so I'm holding off paying out big bucks for an AGM.
    (Preventative maint has it's benefits = the orig batt is over 5 yrs old. But I don't expect too many more, so that AGM may be here soon...)
  11. Feb 25, 2022 at 3:26 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Exactly. Had a buddy flick a bic-lighter to check the water levels in my sisters battery ( long time ago )...
    All I can say is if he wasn't wearing glasses he would have been blinded - BOOOOOM !
    eurowner and TartanEagle[QUOTED] like this.
  12. Feb 25, 2022 at 3:34 PM
    TartanEagle
    '17 ACLB 4x4 MT
    Hope he bought a lottery ticket that day. Lucky SOB. Glad to hear he kept his eyes!
  13. Feb 25, 2022 at 3:57 PM
    19OR
    Jay
    What the frame? Lol
  14. Feb 25, 2022 at 4:00 PM
    19OR
    Jay
    I was thinking the battery got spilled somehow. I’ve never topped off a battery is it just distilled water and you look inside and fill it to the top of the cells?
  15. Feb 25, 2022 at 4:12 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Optima red top for the win. KDMax tune including the AGM up voltage to 14.2? Priceless! @TWTaco
  16. Feb 25, 2022 at 4:16 PM
    TartanEagle
    '17 ACLB 4x4 MT
    Only use distilled water. Other water will deposit minerals and short out the cells, slowly killing the battery.
    Yep, pull off the rectangle caps on top -carefully- to access the individual cells. You can then see the fluid levels. The "neck" that the removed caps fit in, has a notch/slit at the bottom (near the fluid). Only add water to reach that notch, not above it.
    - Above won't hurt the battery, but it will spill much more readily. And if there is ever an over-charge condition, that will boil it out (i.e. spill). The truck is not likely to create an over-charge, but if the voltage regulator for the alternator (or solar panels) goes wonky it can happen.
    Way back when, there was a product called VX-6. It could be added to a completely dead battery and get it working like new again! As long as the batt wasn't physically damaged, with a hole or the likes.
    It must have been mostly sulfuric acid and a wee bit of water. It was great! But no longer on the market - at auto-parts stores anyway. That was the ONLY thing I ever put in a wet-cell battery other than distilled water.
  17. Feb 25, 2022 at 6:53 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    My 19 still looks brand new in that area still with original battery. I’d say you have an issue and would dump that battery and use baking soda to clean the area with some black touch up paint.
  18. Feb 25, 2022 at 7:07 PM
    atlsmedic
    atlsmedic Kinda retired
    ATL
    2017 Black TRD OR
    Mine looks the same as yours. Remember that you’re in a message board with people who care enough about their trucks to be on a message board. Everyone will tell you to essentially lose your mind about it, or you could just realize that you own a truck and a little rust on the bracket that holds your battery in isn’t going to be the end of the world.
  19. Feb 25, 2022 at 7:11 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Looks like the original battery must have leaked acid. I'd pull the battery and tray and then clean the area with baking soda as mentioned above.
    Then I'd rattle can it, and hit it with some cosmoline before reinstalling everything.
    Probably overboard, but I don't like seeing rust.
    I wish I could be like the guy above.
    Skydvrr likes this.
  20. Feb 25, 2022 at 7:18 PM
    atlsmedic
    ATL
    2017 Black TRD OR
    Lol, it’s taken a lot of practice to get to this point of not giving a shit.
    Toycoma2021 and DTaco18[QUOTED] like this.
