corrosion on battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zombie Runner, Jul 7, 2010.
  1. Jul 7, 2010 at 9:03 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Last night my truck wouldnt start..I checked the battery and there was a bunch of corrosion on my positive terminal giving me a weak connection. I cleaned it off with a wire brush and it started up fine. This has happened about 3 or 4 times in the last year.
    is there a way to keep corrosion out?
  2. Jul 7, 2010 at 9:08 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Are you doing anything each time besides just cleaning them?
  3. Jul 7, 2010 at 9:12 AM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    Yep you had likely a nice brown coating of Lead Oxide on the positive terminal. I can't remember how many no starts I cured merely pulling the cables off and cleaning the terminals at the gas pumps 40 years ago.
    Most any automotive store will have some stuff you can spray on a clean terminal. I used just plain old chassis or wheel bearing grease, a light coat on the clean terminal or you could get some silicone grease too. I wonder why its corroding, the battery a sealed type? Corrosion used to be caused by charging and the fumes condensating upon the terminals and some battery acid being released during the charging process. You might clean the entire battery, baking soda and water works well to neutrailize the external acid on the battery BUT don't get it inside of the battery. grab a voltmeter and place across the battery when the engine is running. Generally that voltage should read between 13.8 to 14.2 volts DC.
  4. Jul 7, 2010 at 9:18 AM
    stick114
    stick114 Active Member
    Hot Springs, Arkansas
    TRD SPORT
    ^^^X2 Use the grease
  5. Jul 7, 2010 at 9:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    its the stock yota battery. its kinda dirty but not bad. No i havent done anything other than just scrape off the corrosion, I guess I need to fully clean the terminal and the wire and spray some cleaner on it.
    Ill grab some grease today
  6. Jul 7, 2010 at 7:19 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    The felt pads work great also.
  7. Jul 7, 2010 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    clean with baking soda and water....dry off and spray battery terminal protectant on it.
  8. Jul 7, 2010 at 7:20 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    x2. This was recommended to me, and for only 2 bux or whatever, it was worth a shot!
  9. Jul 7, 2010 at 7:56 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I just spray it with white lithium grease, works great.
  10. Jul 7, 2010 at 7:59 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    x2:D
  11. Jul 9, 2010 at 5:44 AM
    rgolden5724
    rgolden5724 Active Member
    N40 W80
    2006 TRD Offroad
    Pretty much stock
    Clean it with baking soda and water, and spread a thin coating of dielectric grease on it.
  12. Jul 9, 2010 at 5:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I got a can of some spray shit from wal mart. it changes color on battery acid to let you know where its at...that was a big selling point for me since I dont know what corrosion actually looks like :rolleyes:
    Im gonna get some of those felt pad things. I though about maybe soaking the battery in gasoline and then cleaning it off with some fire..less scrubbing involved that way
    :boom:
    thanks for your help guys :D
  13. Jul 9, 2010 at 11:01 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    chicken dinner!
    note: coca-cola will also clean off the corosion if you are low on baking soda, or just want to puzzle your neighbors for a bit.
  14. Jul 9, 2010 at 11:03 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  15. Jul 9, 2010 at 11:24 AM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    mine did the same not stating thing a while back and after cleaning it it would stay good but if i put the rubber cover over the terminal it would absorb the grease and it would go back to not starting again. might come in handy to kno that haha
  16. Jul 9, 2010 at 11:28 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    after you get it cleaned... pick up a pair of chemical battery washers for each terminal and use some spray battery terminal protectant as stated above. clear terminals for months/years
  17. Aug 10, 2010 at 6:59 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. 265/70/16 Pathfinder AT. NST Lite Pulleys
    mine is corroded up, but not at the terminal.
    i had to do a baking soda bath a few times and a steel brush.
    i already have the felt pads.
    the corrosion is on the connector to the terminal.
    so bad that it corroded completely through my amp cable and started creeping about 8" down the cable and now i cannot get the nut off to replace the connectors.
    as i twist on the nut, it is so stuck (after lots of penetrating fluid) it wants to turn the terminal post.
    now i am afraid it is creeping down the main power cable and the one to the fusebox.
    had anyone replaced the main positive cables.
  18. Aug 10, 2010 at 7:04 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ive never replaced battery cables before. I dont think it would be to hard tough?
  19. Aug 10, 2010 at 7:06 AM
    sockmonkey
    Greg
    yeah, not sure how they are connected at the other end (opposite battery)
  20. Aug 10, 2010 at 7:15 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I thought it ran to the alternator but now that I think about it I have no idea :notsure:
