Cost Effective Tips to Make your new 2nd Gen last forever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkman, Dec 10, 2012.
  1. Dec 10, 2012 at 9:50 AM
    junkman
    junkman [OP] Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Ok, looking for what I can do now with my new truck to 1) make it last longer and 2) reduce the cost of long term ownership.
    Example - I have seen posts about LCA bolts not being lubricated from the factory, resulting in siezed bolts that will prevent a good alignment and the need for new control arms. http://www.tacomaworld.com/forum/2nd-gen-tacomas/217265-lca-question.html
    Lubing the bolts when new and periodically would seem to be a cheap and easy way to prevent this problem.
    There must be a bunch of other things that can be done like this to make my Tacoma last longer and make ownership cheaper and easier.
    Lets hear some more examples.
    List So far: (if you have links to posts on anything please post below and I will add them)
    1) Lube the LCA bolts http://www.tacomaworld.com/forum/2nd-gen-tacomas/217265-lca-question.html
    2) Add extension hose off air con condenser drain line to prevent drainage into frame channels
    3) Extend rear diff breather - allows diff pressure to equalize and prevents hot diff pulling in cold water through seals if you go through water
    4) Frequently inspect underside, paint and lube, maybe seal with Fluid Film or other such sealant. Wash off after exposed to road salt.
    5) Periodically lube locks and hinges
    6) Change brake fluid and clutch fluid every two years. It's easy, cheap, improves braking performance, and prolongs the life of brake components. (Also power steering fluid)
    7) If you have 4wd, you need to engage it occassionaly - owners manual says 10 miles/month - But - you should not do this on dry pavement as you may do more harm than good.
    8) Keep engine bay clean. A clean engine bay looks nice, but it also makes it much easier to identify problems early, it inhibits corrosion, and it's much nicer to work in a clean space.
    9) Install an Oil Catch Can http://www.tacomaworld.com/forum/2nd-gen-tacomas/231227-oil-catch-can-install-guide.html
    10) DON'T FORGET TO GREASE YOUR DRIVESHAFTS! http://www.tacomaworld.com/forum/te...ntire-drive-shaft-u-joints-5-zerks-total.html
    Other maintainence issues to be aware of:
    1). Blower motor chirp http://www.tacomaworld.com/forum/2nd-gen-tacomas/28355-blower-motor-squeek-chirp-low-fix.html
    2). Needle bearing replacement http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
    3. Wind whistle noise. http://www.tacomaworld.com/forum/2nd-gen-tacomas/189392-2012-whistling-sound-indentified.html
    :cheers:
  2. Dec 10, 2012 at 9:55 AM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    I don't personally know for the 2013 Tacomas, but for 05 and 06 I know that just driving it and using it for its intended purpose (as a truck) worked for people that kept on regular maintenance. I know an 06 TRD Sport v6 that has probably 300,000 on it now (haven't seen it in a long time) that was just kept up with oil changes, plugs, air filters, and other routine stuff and the only other things that needed to be changed were tires and shocks. Was used as a work and hunting truck. Work was for seamless epoxy floors and hunting in the New England and PA areas. I know there is a guy on the forum that uses his early second gen as an overland truck and it has a lot of miles on it
  3. Dec 10, 2012 at 10:01 AM
    junkman
    Erik
    Louisville
    Yeah, I know they are supposed to last - but want to make sure - the post above about the LCA bolts would definately seem to be a good move because no one wants to spend $1000 if it can be prevented and seems the prevention would be close to free, and yet it doesn't seem like common knowledge or would be considered routine maintenance. Looking for other such tips.
  4. Dec 10, 2012 at 10:03 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    I like to crawl under my veh with some spray paint and hit as much as I can to keep the rust down. I also lube all the hinges and locks
  5. Dec 10, 2012 at 10:04 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Adding an extension hose off the end of your AC condenser drain line to prevent it from draining into the frame channels. Thats my big one.
  6. Dec 10, 2012 at 10:11 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Good idea!
    I extended my rear differential breather.
    Also, either keep up with rust like Billy mentioned or have the truck undercoated early.
  7. Dec 10, 2012 at 10:14 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Proper maintenance and don't cheap out on what fluids and parts you use. If you don't want it to wear and tear faster don't lift it . . .
  8. Dec 10, 2012 at 10:17 AM
    junkman
    Erik
    Louisville
    Great!
    There are 3 more good ones -
    1) Extension hose off AC condenser drain
    2) Extended rear diff breather
    3) maintain chassis with paint/lube or maybe fluid film?
  9. Dec 10, 2012 at 10:18 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Keep it stock and keep up with maintenance. Hit 700k in no time lol.
  10. Dec 10, 2012 at 10:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    LED interior lights, stubby antenna, Pioneer in dash screen, good driver mod.
    thats a good idea. I havent heard of that one before.
  11. Dec 10, 2012 at 10:18 AM
    brian
    Elizabeth City, NC
    I tried telling this to many New Englanders on this forum before. No one seems to understand that you can't make a truck rust-proof, especially in the New England environment. I did exactly like Billy mentioned at least once a year when I was in Cape Cod. When people come on here bitchin about rusting frames, I'm sorry they get absolutely no pity from me.
    I'll take a shot of my AC drain extension, it was one of my first mods and first rust spots that developed on the frame.
  12. Dec 10, 2012 at 10:22 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Fluid maintenance, mechanical maintenance, washing the truck are things I like go keep up to date. Gonna do my spark plugs again.
  13. Dec 10, 2012 at 10:27 AM
    Pugga
    Massachusetts
    F-150 Mod
    I actually bought a fluid film kit to undercoat my truck and am second guessing it. It is a great product and will protect the frame but, because it never dries, it collects road grime and crap on your frame. This isn't an issue as far as protection, it's just doing it's job but it means if you have to get under the truck to do work, if you touch anything, you get a layer of thick black crap all over yourself or whatever you're wearing.
    I'm not trying to bash the product, it does it's intended use very well from what I have seen, I just don't want it everywhere on my underside.
  14. Dec 10, 2012 at 10:32 AM
    junkman
    Erik
    Louisville
    Yeah - I have heard that as well. Have been debating this one with myself as I am not in a super high road salt area. For me, maybe just periodic inspection and touch up, spaying off road salt would be effective enough and more pleasant for getting under the truck.
  15. Dec 10, 2012 at 10:45 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    Id say use a dry lube like teflon for that. It should last longer and not attract dust and dirt.
  16. Dec 10, 2012 at 10:45 AM
    Failure2Comply
    Failure2Comply Well-Known Member
    Virginia, USA
    05 Access TRD/SR5 4x4
    NFab bars, bed mat, Weathertech mats.
    Now that sir is a great idea and I look forward to seeing your mod for it. :cheers:
    This is a great thread, keep um coming. LCA will get done this weekend along with ac drain.
  17. Dec 10, 2012 at 10:52 AM
    junkman
    Erik
    Louisville
    Would be great if you could do a thread with pics on these......
  18. Dec 10, 2012 at 11:17 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    X2, how are you supposed to lube the LCA bolts? Just spray some dry teflon lube and jack the truck up and down? :confused: Doesn't seem like it would penetrate very far.
  19. Dec 10, 2012 at 11:18 AM
    BostonBilly
    Easton
    I am going to mark the cams then pull them out and use neverseize
  20. Dec 10, 2012 at 11:22 AM
    Pugga
    Massachusetts
    F-150 Mod
    You have to pull the LCA bolts out, apply neverseize or grease, and stick them back in. Make a mark from the cam bolt to the frame so you can re-align everything when you're done.
