Costco Interstate Batteries
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BizzyBone, Feb 27, 2024.
  1. Feb 28, 2024 at 12:41 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bottom line you have no ideal who made the factory battery. It may say Toyota but they didn't make it. I would also say they got them from the lowest bidder as they buy them by the hundreds. A bag full of modules draw less current than a head lamp.
  2. Feb 28, 2024 at 5:19 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    I had one in a Nissan Frontier, and it lasted the standard New Mexico 3 years. The best battery ever was the original Honda S2000 one in my 2005, that made it to 2015. Unfortunately, they’re not imported.
  3. Feb 28, 2024 at 11:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    There is a safety factor built into using a 24F/27F, aka ‘reverse terminal’, battery in our rigs. If you look at the engine bay in most, if not all, vehicles today, you may notice the positive post is positioned away from the nearest vertical wall whenever possible. If the wall caves in, as in an a collision, there is a higher chance of metal to battery-post contact with the post nearest that wall.
    As with most have said, I, too, usually get a Costco Interstate or Walmat battery. OEM was 27F for my Taco, but, since I have a dual battery system, I now have a 24F as my primary and a 34 as my auxiliary. If my 24F dies on me, my Taco can start and run off the 34.
    2015WhiteOR, RHHousehold and jackn7 like this.
  4. Feb 29, 2024 at 5:06 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Toyota battery in my 2011 2 years, NAPA replacement is still starting the truck. Gets pretty cold Maine this time of year. I don't remember seeing a date stamp on the Toyota battery but I'm going to guess in may have been older than the truck. All most identical case with my diesel tractor the only difference is it may sit for days on end I think it to has a NAPA battery. The camper has two Wal Mart batteries they also have some age on them, they are on a smart charger in my barn. Bottom line check the date stamp on a battery before you buy it.
  5. Mar 1, 2024 at 6:38 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I have a Costco interstate agm for baby taco it cost like 200 bucks
  6. Mar 1, 2024 at 10:16 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    I, of course, believe you that you use the 27(non F) marine battery, so this is more for information and discussion than anything else
    But warranty aside, I was always under the impression that marine/deep cycle batteries couldn't discharge "fast enough" for a vehicle...as in starting. Maybe that's old thinking...or maybe it was never true. Thoughts?
    Another possibility is that I'm combining two types of batteries (marine and deep cycle) in my mind, when they are really not the same at all. I see the CCA of your battery is 940ish, so that's obviously plenty...I also see that you derived that from MCA, which I have no idea what that is to be honest lol. Again, I believe you and your calculations...just discussion and education for me and probably for others too.
    Any info and thoughts you're willing to share is appreciated.
  7. Mar 1, 2024 at 12:38 PM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    The picture below was taken about 30 seconds before I started to type this post. So, yeah, I am running the Deep Cycle Marine battery in my truck. If the positive post should ever make contact with any metal, it is because I have been in a severe accident, and I have bigger problems than a shorted battery.
    Marine batteries use thicker lead plates than conventional car batteries, and I believe that they are slightly more resistant to sulfation. The number of plates is rumored to be fewer, but I have never seen ANY proof of this. Nor have I seen any issue with having sufficient amperage or voltage to spin the starter motor in either my Tacoma (4.0L V6 - gasoline) or my sailboat (.893L I3 - diesel).
    A marine "Starting" battery is essentially a car battery with dual posts.
    Here is a cutaway of a 12V Marine "Starting" battery (left) versus a 6V Marine "Deep Cycle" battery (right):
    [​IMG] - credit Rodd Collins
    Which would you rather run?
    I run EVERYTHING (including the starter motor) on my sailboat from the "House" bank. The "Start" bank on the boat is simply a Group 24 battery, that I use in the same way that you would use a spare tire - when another battery dies, and only when I have to. If a Deep Cycle battery is good enough to start the diesel on my boat, it is good enough for my Tacoma.
    MCA = Marine Cranking Amps which are equal to CCA (Cold Cranking Amps) * 1.25
    If you REALLY want to get into the weeds of what a Marine Deep Cycle battery is, then let me point you here: https://marinehowto.com/what-is-a-deep-cycle-battery/
    I hope this helps.
  8. Mar 1, 2024 at 12:50 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    i have one, no complaints. My truck is stock
  9. Mar 1, 2024 at 12:52 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Is the $150 right? Last time I remember paying closer to $100 for the starting batteries. I run those Costco batteries in everything - 5 starting batteries and 2 deep cycle currently installed and have used them exclusively for the past 20+ years and they easily last 5+ years for me. I did have one prematurely die and Costco did it's thing.
    jackn7 and Sprig like this.
  10. Mar 1, 2024 at 1:14 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    There is only like 3 battery manufacturers in the U.S . Johnson controls makes over 50 percent of those so mostly you are buying the same ish battery the difference being the warranty and the customer service. Really hard to beat costco customer service.
    jackn7 and hr206 like this.
  11. Mar 1, 2024 at 6:44 PM
    jproffer
    Jim
    Perryville, MO
    I'll definitely read that. Thank you
    I think I'm going to get the same battery you have...it's about time anyway.
  12. Mar 18, 2024 at 10:04 PM
    HazMatKat413
    HazMatKat413 Active Member
    2011 Tacoma Crew Cab, 2003 Crew Cab
    Husky X-Act Floor Mats F&R Bakflip MX4 hard tonneau Undercover swing away tool box
    Everything Logger just stated is exactly correct. The only difference between the Interstate Battery and a store branded battery made by Johnson Controls is going to relate to the formulation of the lead plating in the battery and the sulfuric acid. Battery manufacturers can essentially "limit" battery life by playing with those formulations as it relates to the specific gravity of the acid.
    Go with the interstate, its the gold standard especially in cold weather climates. There's a reason why most repair shops stock them, because they stand by their warranty and hardly have issues.
    Batteries from advance auto and auto zone have been predisposed to premature failure in the plates causing large flakes to fall off the lead plate into the bottom of the battery essentially shorting out the battery internally. Not sure if thats been addressed yet
  13. Mar 18, 2024 at 10:07 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    I have Interstate Battery in my Tacoma and my RV. 3 year life span?
  14. Mar 19, 2024 at 2:29 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    For the record, Johnson Controls sold its battery business in 2019 to the private equity firm, Brookfield Business Partners.
    Clarios is the name of the business now.
  15. Mar 19, 2024 at 3:42 AM
    #35
    cmoore
    cmoore Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    I have the Costco Interstate in my '06 Tacoma. The battery will be 6 years old in August of this year. No problems or complaints.
    jackn7 and 23MGM like this.
  16. Mar 19, 2024 at 8:14 AM
    #36
    BizzyBone
    BizzyBone [OP] Well-Known Member
    Thank you all. I called Costco and they had it in stock, so I went with the Interstate battery.
  17. Mar 19, 2024 at 5:13 PM
    #37
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Duralast in my truck also going on 7 years,not a single problem.
    jackn7 and BizzyBone[QUOTED][OP] like this.
  18. Mar 21, 2024 at 6:05 PM
    #38
    Xrrman
    Xrrman Member
    2015 Tacoma Limited
    Not to get off this Costco-specific topic, but are these the same batteries that the Interstate Battery stores sell? Nearest Costco to me is 50 miles away, therefore I don't have a membership, but I think my battery has seen better days. Hate to pay $50-$60 more, but...
  19. Mar 22, 2024 at 10:57 AM
    #39
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    ran interstate batteries in 3 of my other vehicles and never had a problem. will most likely get an interstate from costco when my taco battery dies.
    Like my dad always says, the best car battery is the battery with the longest warranty.
    jackn7 likes this.
  20. Mar 23, 2024 at 3:12 PM
    #40
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    The Costco Interstate batteries and the ones sold in Interstate battery stores are two different batteries. The Costco ones are a generic battery with Interstate stickers on them(not that they are bad). The Interstate battery store batteries are said to be higher quality batteries but their price is a lot higher and their warranty was cut to 30 months. Costco Interstate batteries have to be returned to Costco if they are defective, the Interstate battery store will not replace a Costco Interstate battery under warranty. I know because the garage I work for sells Interstate batteries.
    HazMatKat413 likes this.
