Costco refusing to mount tires on Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wawuzit, Feb 21, 2019.
  1. Feb 21, 2019 at 7:36 PM
    #41
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I would never trust a corporate entity to do any kind of work on my truck...
    CLICK HERE to see how BJ's fucked up a simple tire job on my Tacoma!
  2. Feb 21, 2019 at 7:38 PM
    #42
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    it pretty simple you just cone the wheel and tire up to the balancer as normal like you would regular balancing. press the road force settings on the machine then the balancer will have you mark a position on the wheel then the tire. all you do is let the air out of the tire break down the beads the rotate the tire so the mark lines up with the wheel, air it back up take it back to the balancer then recheck the road force.
  3. Feb 21, 2019 at 7:43 PM
    #43
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Do you think the Hunter equipment is that much better than the Coats machines used by Costco and some others?
  4. Feb 21, 2019 at 7:44 PM
    #44
    modifiedtaco
    Alex
    having a loose wheel or scratched wheels is not uncommon in the tire business. what really matters is how the company behaves after the incident is brought up. There are lots of factors for loose wheel or scratched wheels I'm willing to bet most shops with a tire machine have scratched a wheel or had a loose wheel at some point.
    The Real Moondog likes this.
  5. Feb 21, 2019 at 7:47 PM
    #45
    modifiedtaco
    Alex
    I've used both coats and hunter equipment at work. as far as balancing goes as long as the machine is properly calibrated it should work the same way.. the difference usually comes as to how many time the machine brakes down or how long it will last. keep in mind most balancing issues usually come from operator error..
  6. Feb 21, 2019 at 7:51 PM
    #46
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Here's a good one:
    A friend I used to hang out with told me about his former job working at a small tire shop in a small rural town on a fairly busy highway (2 lane).
    When business slowed down, his boss (the owner) would grab a box of nails, tell him to get ready to work his a$$ off, leave and return a short time later. You can guess what was happening. And it worked, my friend would work his a$$ off the rest of the next couple days repairing flats.
    This was in a small rural town in CA, alot folks traveled thru going to work in the larger towns nearby.
  7. Feb 21, 2019 at 7:53 PM
    #47
    smikec
    smikec Well-Known Member
    Here's a good one - turn in your friend and his boss to the police
  8. Feb 21, 2019 at 7:54 PM
    #48
    The Real Moondog
    Moondog
    Thanks again. The last time I balanced a tire was as a kid and we had a “bubble” balancer. Look that one up! :). I would add that the guy that did my tires at the local Costco gave me his card and told me to ask for him or another guy and to only let them do my Taco tires. They did my GTI tires and they are balanced perfectly. I can’t believe how much better it rides and handles now. FWIW, I’ve always “upgraded” my Continental and Pirelli tires on my German cars with cheaper Kumho and they have been perfect. I still wish we had a local DTD but we don’t so I’m just trying to find a place that won’t screw my stuff up. It seems like we always need tires with 6 vehicles!
  9. Feb 21, 2019 at 7:55 PM
    #49
    The Real Moondog
    Moondog
    Dang.....uh, that’s a funny not funny story there. Geez, be sure and get the road hazard in that town.
  10. Feb 21, 2019 at 8:02 PM
    #50
    MtnFisher
    ZeroDrift
    When he told me his story he had already moved on, and already at least five years had passed.
  11. Feb 21, 2019 at 8:34 PM
    #51
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I thought this was called "lateral run out". Road force being where the machine actually applies pressure to the tire while it spins to measure loaded balance
  12. Feb 21, 2019 at 8:46 PM
    #52
    modifiedtaco
    Alex
    yes the road force machine applies pressure downward on the tire. The machine will give you a measurement of road force. The tolerance is dependent on if its a passanger tire or LT tire. If the road force measurement is higher than acceptable the machine will tell you where to rotate the tire on the rim to give you the smoothest run out. Once road force is good you still have to balance tire as you normally would.
    Amanelot[QUOTED] likes this.
  13. Feb 21, 2019 at 9:09 PM
    #53
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Is there a code word to use so I don't have to argue with Johny/Bobby/Jim?
  14. Feb 21, 2019 at 9:36 PM
    #54
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    BJs sucks, actually should be renamed to blow jobs. A few years ago I got a membership because I found cheaper Michelin tires there. They’re all assholes maybe because they’re only tire techs and they pay them like $7/hr. That’s why they only mount tires, nothing else like alignments.
    Now I go to Mavis. They’ll put on anything that I take them. Plus, they’re a full on service center with alignments, suspension installs, oil change, etc.
    https://m.mavistire.com
  15. Feb 21, 2019 at 9:51 PM
    #55
    The Real Moondog
    Moondog
    I’ve found please, thank you, and I appreciate it generally work very well. :). The old saying you catch more flies with molasses than vinegar is generally true. I try to be as nice as possible until I’m given no other choice. Best of luck. :)
    Gunshot-6A and hoarder23 like this.
  16. Feb 21, 2019 at 10:20 PM
    #56
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've run Into this problem trying to find a tire store to mount a set of slicks and or drag radials . All of the big name tire stores refused to mount these tires for me . I did finally find a small Mom & Pop tire store that not only did they do the work for me they they only charged me $20 per wheel
  17. Feb 21, 2019 at 11:08 PM
    #57
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
  18. Feb 22, 2019 at 5:25 AM
    #58
    wawuzit
    wawuzit [OP] Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    Looks like everyone agrees its hard to get large tires and rims installed by most tire dealers. Here's my question. Can you order a Tacoma from Toyota that has larger tires//rims installed at the factory? If so. How large?
  19. Feb 22, 2019 at 5:26 AM
    #59
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Maybe go to a tire shop and not a grocery store for your tire work? ...
    ChucktownTaco and JCOOR like this.
  20. Feb 22, 2019 at 5:36 AM
    #60
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    I have never had issues with discount tire. I put 255/85/16 on my Tacoma without a fuss and 37x12.5 on my other truck. They were skeptical if the 255 would fit but they had no problem doing it
