Could Axle Wrap be the root of my problems?
Discussion in 'Technical Chat' started by I Liquid I, Oct 25, 2011.
  1. Oct 25, 2011 at 10:27 PM
    I Liquid I
    I Liquid I [OP] Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Hello,
    I fixed my driveshaft problems some time ago. I replaced all U Joints and the Carrier Bearing. The driveshaft still had some play where it joins with the transmission. I think it was normal.
    Anyhow, truck ran great, no sounds, etc. Forward to today, it is starting to sound again. It is like a "tack tack tack tack" sometimes when accelerating. Once you start braking it is gone. It does not do it all the time, so I guess I am still "safe".
    Anyhow, I have noticed that my leafs are pretty sad... as in, downwards. I need to replace them. Anyhow, I am getting some axle wrap now and then.
    Could the axle wrap be what is damaging my driveshaft components?
    Thanks!
  2. Oct 31, 2011 at 10:07 PM
    I Liquid I
    Puerto Rico
    Well... it is doing it less now. When it does it however, it gets on my nerves. Sounds like an old truck... Oddly enough, it usually does it more at low speeds.
    Shit... I might have to take out the f*&%* driveshaft assembly out again.
    Only other play I noticed that indeed is causing noises are the shocks, but that will change soon with 5100 or OME setup when time permits.
    Anyhow... if anyone got any ideas... please do post.
    Thanks!
  3. Nov 1, 2011 at 12:22 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    If it goes away when you let off the gas, (unload) then it is more then likely a pinion bearing. Noises like this is like telling a doctor, "I had a cough last week. Please diagnose me." A video next time please?
    AlaskanTaco
  4. Nov 1, 2011 at 1:38 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I had this years ago with a big lift Jeep....turned out to be worn U joints.....which is a common problem with driveshafts at extreme angles. Good thing is....u joints are cheap & relatively easy to swap out yourself.......worth a try. ;)
  5. Nov 1, 2011 at 3:14 PM
    I Liquid I
    Puerto Rico
    It is not likely I will be able to produce a video for this. Sorry. I will look into the pinion bearing matter though.
    All U joints and the Carrier Bearing have been replaced not so long ago. I lubricate them very frequently too.
