could cold weather cause worse mpg?
Discussion in 'General Automotive' started by outlaw7, Dec 20, 2010.
  1. Dec 20, 2010 at 8:40 PM
    outlaw7
    outlaw7 [OP] Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    My daily driver is a 91 Suzuki swift 1.3 2barrel 5 spd. I originally purchased about a year ago and my first fill up MPG was around 28. After changing plugs wires cap rotor fuel filter the MPG started to get better each fill up all the way to my best 45. But the last few tanks have dropped to around 38-39. My commute has not changed or my driving habits only change has been winter weather so back to my title, could the temp drop cause a drop in fuel mileage?
  2. Dec 20, 2010 at 8:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    They put ethonol in our fuel and lowers the economy. The cold should benefit our economy unfortunately the government knows best.
  3. Dec 20, 2010 at 8:44 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Short answer is yes
  4. Dec 20, 2010 at 8:45 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    yeah its the gas, always worse in the winter but keeps moisture from building in the tank
    also letting the car worm up for longer add up to quite a bit of used fuel
  5. Dec 20, 2010 at 8:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    To add to the fuel being the issue, and longer warm ups, the colder air is more dense, thus running more fuel to keep the propper A/F ratio.....all these combine to give less MPG in the winter months.
  6. Dec 20, 2010 at 8:48 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Thanks for the quick reply guys.
