Could I put on Billies set at 2.5" with my 884 coils?
Discussion in 'Suspension' started by DestinTaco, May 11, 2011.
  1. May 11, 2011 at 8:16 AM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    or would that make my front end super high? What would I have to do to just have 2.5" of lift in the front if I got Billies? Would I just simply take off the 884's? Thanks.
  2. May 11, 2011 at 8:20 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    Don't stack lifts! Anything that gets you over 3" of lift (without a drop bracket or SAS) will destroy your ball joints and/or make the ride unbearably rough and/or top out and damage your shocks.
  3. May 11, 2011 at 8:25 AM
    DestinTaco
    Destin, Fl
    I'm with ya...so if I got Billies and set them at 2.5" what would I do for coils?
  4. May 11, 2011 at 8:26 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Set the billes @ 0 with the 884's & get 2" of lift or remove the 884's & set the billies @ 2.5". May be able to set billies @ .75 & run the 884's not sure on that... PM Chris 4X4 that guy knows everything. Good luck!
  5. May 11, 2011 at 8:27 AM
    tegdog
    tegdog Taco Lover
    Indiana
  6. May 11, 2011 at 8:32 AM
    DestinTaco
    Destin, Fl
    If I remove the 884's and set the billies at 2.5, don't I still need coils to go with them?
  7. May 11, 2011 at 8:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, he meant remove the 884's and use your stock coils if you want to set the Billies at 2.5.
  8. May 11, 2011 at 8:55 AM
    tegdog
    tegdog Taco Lover
    Indiana
    Thanks, I should have been more clear my bad.
  9. May 11, 2011 at 9:05 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Don't set the billies at .85 and run 884 coils! It's a really bad idea. If you set the 5100s at 2.5 id be REALLY interested in the 884s!:D
  10. May 11, 2011 at 9:08 AM
    DestinTaco
    Destin, Fl
    Got it. Thanks for the help. I'm going to keep my 884's for a while. I'm just thinking ahead.
  11. May 11, 2011 at 9:09 AM
    NC15TRD
    Nick
    PA
    Damn, well keep me in mind if you decide to make the change!
  12. May 11, 2011 at 9:21 AM
    DestinTaco
    Destin, Fl
    will do.
  13. May 11, 2011 at 9:26 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Just stay with the 884's and the billes at zero, you get ~2" of lift yet keep the full movement of the shock. I bet you will be very happy with that setup. Anymore lift and you step up into another price range completely.
  14. May 11, 2011 at 4:48 PM
    tegdog
    tegdog Taco Lover
    Indiana
    That's a good point, you will need new UCA's to get a decent alignment if you go above 2.5" also. If the 1st offer falls threw I'll take those coils.
