Could I run a 275/60 or 275/65 tire without any rubbing issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernGirl83, Oct 18, 2024.
  1. Oct 18, 2024 at 10:16 AM
    SouthernGirl83
    SouthernGirl83 [OP] New Member
    Nikki Parker
    2018 Toyota Tacoma TRD, RWD
    3" Lift with a 2/1 leveling kit, 275/55/R20 tires and rims
    Hey everyone, I have a 2018 Toyota Tacoma TRD RWD with a 3" lift and leveling kit. I currently run a 275/55/R20 tires and rims with a -19 offset rims. I have no rubbing issues but I'm wanting to fill up that render well gap a little better could I run a 275/60 or 275/65 tire without any rubbing issues??? Any help is appreciated
  2. Oct 18, 2024 at 12:27 PM
    zanman5
    zanman5 Member
    PNW
    '22 TRD Pro 6MT
    Lift, wheels, tires, short shift, many more
    With a 20" rim the 275/60 is right at 33" tall and the 275/65 is 34". You should be ok with the 60 but I'd guess the 65 is going to rub. Check the actual specs on the tire height for your 20s and be sure to consider the rim width.
    SouthernGirl83[OP] likes this.
