Could I still have axel wrap with new leaf springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itisreallycold, May 18, 2013.
  1. May 18, 2013 at 1:43 PM
    Itisreallycold
    Itisreallycold [OP] Active Member
    Minnesnowta
    Ol' Rusty
    I just replaced my leaf springs with wheelers 4 leaf set, and also put a new set of bilstein 5100 shocks with intent to fix my wrapping axel. My truck feels a lot smoother, but if I accelerate a little faster than your average grandmother I still get a popping noise. I can only make it pop when i accelerate from a complete stop. Should my new leafs have fixed this problem, and the noise is coming from somewhere else? Or is it possible that my axel is still wrapping? Another revelant thing about my truck is when I shift into reverse it will sometimes dip down a noticeable amount, dose that sound like a possible contrubiting factor to my dreaded popping noise or is that just a whole new problem?
  2. May 18, 2013 at 2:16 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Sounds more like a drive line issue
  3. May 18, 2013 at 2:17 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Check u joints
  4. May 18, 2013 at 3:01 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    and center bearing if two piece shaft...
  5. May 18, 2013 at 3:06 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Will the carrier cause a thud while stopped?
    I thought it was a vibe at speed that it caused.......I have thrown on 2 diff types of cb drops.....they caused vibes (low speed takeoff). Turns out I didn't need a cb drop, even tho many suggested getting 1 with my lift.....all it did was cause problems.
    When it was removed, I had no vibes.
  6. May 18, 2013 at 3:36 PM
    Itisreallycold
    Minnesnowta
    Ol' Rusty
  7. May 18, 2013 at 5:02 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    If you haven't retorque your u bolts after you installed it, you should.
  8. May 18, 2013 at 5:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Axle wrap is just something that happens with leaf-sprung suspension systems.
    Yes, check all of the above components to make sure you don't have something else getting ready to fail, but axle wrap is unavoidable unless you are running a 3 or 4 link, or at least a stabilizing link from the top of the diff (which will be better for offroad articulation than a 3/4 link).
  9. May 18, 2013 at 5:57 PM
    Itisreallycold
    Minnesnowta
    Ol' Rusty
    Dose this mean I can conclude that the popping/clunking noise is coming from my rear axel and something like Dynachrome Leaf Spring Helpers would cure it? How can I tell if I have a bad U joint? and if any one saw the video I linked is 1/8"-1/4" of play in the drive line normal?
