could i...
Discussion in 'Suspension' started by mr smitty, Jan 7, 2010.
  1. Jan 7, 2010 at 3:59 PM
    mr smitty
    mr smitty [OP] Well-Known Member
    Tennessee
    09 prerunner sport
    Westin Chrome running boards Rough Country 3" lift 17x9 motometal 951 chrome mickey thompson baja atz 285/70 17
    Ride 33x12.5 17 mickey atz's on 17x9 rims with about a 3 inch lift without having to do much trimming?
  2. Jan 7, 2010 at 4:11 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    You could fit it in there with some trimming. The trimming is subjective to how hard you drive your vehicle though. Some trim more than others. If you are going a full 3'' you are going to need to buy new upper control arms in order for you to get it aligned correctly.
    What type of 3'' lift are you looking into? This might help others answer your question better.
    Personally, I'd recommend getting camburg 4'' or total chaos 3.5'' lift spindles because then you have a little more lift and more ground clearance since you are a prerunner. Which should mean a little less trimming.
  3. Jan 7, 2010 at 4:17 PM
    mr smitty
    Tennessee
    09 prerunner sport
    My uncle is going to design a rough country lift and test it out on mine so il see if I can go for a 4" but il take anything that I can get for sure
  4. Jan 7, 2010 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you go 4", you will have no down travel, and the truck will ride like a wagon. IF, your ball joints survive.
  5. Jan 7, 2010 at 4:26 PM
    mr smitty
    Tennessee
    09 prerunner sport
    Down travel?
  6. Jan 7, 2010 at 4:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have roughly 8" of up and down wheel travel in the front. By lifting 3", you take away 3" in which the suspension can travel downward. Leaving 1". By lifting 4", you nolonger have any.
  7. Jan 7, 2010 at 4:36 PM
    1BlkT
    Ty
    90603
    x2
    The truck will ride rough and you will wear out components if you go with that much lift. Unless you buy a spindle lift, not something he will be able to make you, because those aren't easily made.
