could my truck BLOW up?
Discussion in 'Technical Chat' started by Jeffvt0508, Jul 28, 2013.
  1. Jul 28, 2013 at 8:16 AM
    Jeffvt0508
    Jeffvt0508 [OP] Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    So I was tryin to fix my cigarette light and 12v output ( it worked before and stopped..i checked all devices and even bought new ones, but not the problem).. I looked in manual and found that its the AC SKT 100A fuse number 34... my problem is when I looked at fuse box... there is no fuse in the AC SKT slot..so would buying a fuse work? or is it wired into another fuse?
    please help and thanks everyone for the help!
  2. Jul 28, 2013 at 8:22 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    I think the ac socket is for the TRD plugin in the bed, not the lighter. not positive though.
  3. Jul 28, 2013 at 8:30 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Sorry for the premature post! I found it.. the ACC skt is a relay.. not fuse , Although i'm still missing it? but the fuse for cigarette lighter and outlet inside truck is behind the coin tray under steering wheel.. replaced it and works fine now.. I got confused w/ which fuse I was to be looking at .. sorry for the dumb moment..
  4. Jul 28, 2013 at 9:05 AM
    TheGoat
    Justin
    Greenville, SC
    Maybe those flashing lights are getting to you. XD
    My truck doesn't have the ac socket relay either. Its for the plug in socket in the bed of the TRD models.
  5. Jul 28, 2013 at 9:07 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    well then maybe it is those darn strobes... I hate wiring!!
