Could the hole in my air filter have been the problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevinC, Nov 1, 2019.
  1. Nov 1, 2019 at 3:41 PM
    KevinC
    KevinC [OP] Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    2017 4 door crew cab with a 2.7 4cyl with a 3 inch lift and 33s.
    Drove it home 2 years ago, (before lifting it) and went on the interstate with it. It wouldn't stick to a gear at 70mph+, it kept going 4-5-6...4....5-6-4.......5.....-6-4...... and so on.
    I'm thinking ok, maybe it needs to be broken in. No big deal, drove home going 60-65mph without issues and drove it around town for the next 1000 miles. I had already purchased the lift for it, so I slapped it on expecting the issue to be resolved on its own. Took it on the highway a couple times after that, same issue. Slightly remedied the problem by putting the truck in S5 so that it wouldn't ever shift to 6th and starve for power, which made my drives on the interstate a little more comfortable as long as I didn't go above 73-75 mph. Still though, every time another truck would pass me on the highway, the crosswinds would make the truck shift back into 4th gear at 3500-4000 rpms to keep up speed. Not a fun way to drive when you're going 73mph.
    During these 2 years I took the truck to Toyota 4 separate times over this very issue. Everytime I get the old "there's nothing wrong with the truck, it's performing as it should, maybe you shouldn't have lifted it", to which I always respond. "please listen to me, it's been behaving this way since I drove it home on factory tires and suspension, I'm not making this up"
    Anywho, went in for my 20k miles service job today, and they replaced my air filter. As it turns out, there was a small hole in the middle of it with the surroundings that appeared to have been chewed off by a rodent. Mind you, the air filter was never changed, so this was definitely something that happened in the factory, or on the Toyota lot. Anywho, they replaced the filter, and now the truck sounds a lot different. I took it on the highway, and I was going 78 mph GPS speed in 5th gear without an issue. I know with the factory sized tires I could easily go 80+ in 5th and never go above 2200 rpms now that this filter is fixed.
    Your thoughts?
    I am not a mechanic, and I'll be very honest, half the time I don't know what tf I'm talking about, so I need to hear it from other people. Could this have been my issue the entire time? Does a small hole in the air filter make that much of a difference? I was starting to consider re-gearing to 4.88s (again, I dont know wtf I'm talking about, this is just from talking to people) but now I feel very satisfied with my setup. So I'll ask again, what are your thoughts?
    Also: Driving this truck for 20k miles with a bad air filter - is that really bad? Like, eventual engine failure bad? Should I be concerned and have some kind of inspection done?
  2. Nov 1, 2019 at 3:44 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Maybe there’s a dead rodent stuck in your intake.
    BSFord likes this.
  3. Nov 1, 2019 at 3:46 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    “Get it regeared or sell it.” Least amount of words and what others will go on and on about.
    GreyBaldTaco, El Duderino and Boghog1 like this.
  4. Nov 1, 2019 at 3:48 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    How exactly did you come to this conclusion? There is a big hole in the air box near the wheel well that a rodent could easily climb in at anytime and crew the filter. This could have easily happened at anytime.
    Bleep100, Tullie D, Chew and 3 others like this.
  5. Nov 1, 2019 at 3:50 PM
    jowybyo
    Joe
    Baltimore, MD
    Or get smaller tires. 33’s on a 4 cylinder just crush the little motor.
    Garyji, BlackTRD4Me, Chew and 4 others like this.
  6. Nov 1, 2019 at 3:51 PM
    KevinC
    Kevin
    Because the engine has been gutless since I drove it home from the factory, and this filter was never changed. Now it suddenly has more life.
  7. Nov 1, 2019 at 3:52 PM
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    Way to big of a tire for a 2.7 Engine w/auto trans. Been there with a 92 4 runner MT 4 banger and 32” tires. Makes a slug out of them.
    Chew, kahanabob and GreyBaldTaco like this.
  8. Nov 1, 2019 at 3:52 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Are you saying that in 2 years and 20k miles, no one ever checked the filter? That should have been checked at least 4 times in that span of time.
    I think your problem is more to do with heavy ass 33" tires. The filter may have played a part, but the little 4 banger is probably struggling with the taller/heavier tire. A regear may help. But you'll lose top end speed... no?
    BlackGT99, Chew, GreyBaldTaco and 2 others like this.
  9. Nov 1, 2019 at 3:53 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm really suspicious that the air filter itself was the issue. Something with the MAF I would believe though.
    AKGSD, GreyBaldTaco and Boghog1 like this.
  10. Nov 1, 2019 at 3:53 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    That’s the 2.7 4cyl it’s gutless to begin with.
    Chew, GreyBaldTaco and na8rboy like this.
  11. Nov 1, 2019 at 3:56 PM
    jowybyo
    Joe
    Baltimore, MD
    ^^^^ This. I drive a 2.7 4cyl on 33’s. It’s sloooowww and has a hard time staying in top gear on the hwy. just the way it is when you’re super underpowered. Changing your filter to one without a hole isn’t going to make it less gutless. If you did an oil change, that might help. I can definitely tell a difference after an oil change. Or it’s all in my head o_O
    Chew and El Duderino[QUOTED] like this.
  12. Nov 1, 2019 at 3:59 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Definitely in your head. Surprised there's room in there since you always have wood on the mind.
    jowybyo[QUOTED] likes this.
  13. Nov 1, 2019 at 3:59 PM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    A hole in the air filter will not contribute to the transmission shifting. And odds are it didn't hurt the engine.
    Chew and GreyBaldTaco like this.
  14. Nov 1, 2019 at 4:00 PM
    jowybyo
    Joe
    Baltimore, MD
    Your wood is always on my mind.
  15. Nov 1, 2019 at 4:38 PM
    KevinC
    Kevin
    Thank you all for your quick input. I can't stress enough that I'm a total newb, that my questions need to be answered with the patience it requires to raise a special eds kids, and that my opinion needs to be digested with some thick Himalayan pink salt
    Based on what I gathered from you guys, it's not the chewed up air filter. I'm not sure as to why my truck suddenly drives better. Maybe the wind was super low today, or maybe their maintenance ppl sucked in the past and they got some guys who do a better job now. Someone mentioned a dead rat in the intake, I think I would have smelled it by now.
    El Duderino, jowybyo and Boss hoss like this.
  16. Nov 1, 2019 at 4:51 PM
    jowybyo
    Joe
    Baltimore, MD
    Sometimes my truck feels like it has more power than other days. I think it’s just so underpowered that even small differences are noticeable. This time of the year is the worst though. We have winter blend gas and it robs me of power and my mpgs drop by almost 20%.
    KevinC[QUOTED][OP] likes this.
  17. Nov 1, 2019 at 5:03 PM
    Boss hoss
    Richard
    Silverton Oregon
    Small engines can feel like that when the air is thicker and the humidity is lower. Motorcycle engines have the feel of more power at night when the air is cool. I think you may notice it more than most people. Keep on trucking and you well get it figured out.
    KevinC[OP] and GreyBaldTaco like this.
  18. Nov 1, 2019 at 6:39 PM
    KevinC
    Kevin
    I live in Florida though, man. It’s still humid and hot as balls right now.
  19. Nov 1, 2019 at 9:03 PM
    StayinStock
    StayinStock Dare to be the same
    Bob
    Missouri
    Yes I do
    Some
    You probably had a tailwind today.
    GreyBaldTaco and Tacospike like this.
  20. Nov 1, 2019 at 10:43 PM
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    Go slower or re-gear.
    Look for a reputable driveline shop.
