Could this be brake clunk or something else? Please Help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evan7reed, Jun 3, 2025.
  1. Jun 3, 2025 at 6:33 PM
    Evan7reed
    Evan7reed [OP] New Member
    2011 Tacoma TRD
    Camburg mid travel kit with custom Icon 2.5 shocks. Custom rear shock towers and 2.0x12 fox smooth bodies
    Hi there,
    I have a 2011 Tacoma 4x4 w/ 242k on it and am experiencing a clunking noise coming from my front end under slow speed braking and turning. I looked into the “brake clunk” forum and most everyone seemed to say it was common. However, unlike the typical brake clunk symptoms, my truck is making multiple “clunks” as I slow down, whether it be to a complete stop or just slowing down at low speeds. They don’t seem to have a pattern to it like a rotating assembly would, but I’m pretty lost about what it could be. If anyone had any insight, please lmk. Thanks!!
  2. Jun 3, 2025 at 8:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the wheels off and look for broken or missing hardware at the brake calipers. Are the caliper bolts tight?
  3. Jun 4, 2025 at 9:12 AM
    Evan7reed
    2011 Tacoma TRD
    Took the wheel off and nothing seems to be missing or broken. Caliper bolts were also tight when I checked. Could it have anything to do with my cv’s? They were the first thing I checked and both had normal amounts of play.
  4. Jun 4, 2025 at 9:21 AM
    safaridave
    safaridave Active Member
    Richmond, Virginia
    06 Prerunner TRD OffRoad
    try checking your wheel bearings. lift front of truck and try to move the wheels vertically and laterally to check for play.
    b_r_o likes this.
  5. Jun 4, 2025 at 9:23 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...did you check the Sway bar ends links
  6. Jun 4, 2025 at 9:26 AM
    Pnwadventure
    Pnwadventure Well-Known Member
    Kirkland wa
    2006 white access
    Sway bar links and play in the steering rack could also cause clunking
  7. Jun 4, 2025 at 9:32 AM
    Evan7reed
    2011 Tacoma TRD
    I have the sway bar removed, but it could be the steering rack, I haven’t checked that yet. Wheel bearings are fine though, just checked and there isn’t any play in either of the wheels.
    HondaGM likes this.
  8. Jun 4, 2025 at 9:34 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Got a Video:popcorn:
    Evan7reed[QUOTED][OP] likes this.
  9. Jun 21, 2025 at 8:33 PM
    Evan7reed
    2011 Tacoma TRD
    SOLVED!!! Turns out it was actually my lower control arms moving at the bushing as well as a bent driverside control arm...got them replaced and problem was solved.
    knottyrope likes this.
