Could use input from people w/LCE headers
Discussion in '4 Cylinder' started by Sep1911, Aug 4, 2022.
  1. Aug 4, 2022 at 12:37 PM
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    I’m looking for some input from people who have installed the LcE headers on their truck. Really, I’m just wondering if the supplies gasket is good and holds up or should I order OEM gaskets?
  2. Aug 4, 2022 at 12:38 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you only have to use it once the LCE is sufficient. I would go with OEM though in case it ever has to come back off for some reason. Even on the OEM gasket mine eventually started leaking so i cut the OEM flange out and added a flex and v-band. Hope this helps some
  3. Aug 4, 2022 at 6:24 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    I installed them and i was under the impression that they throw in an OEM gasket from toyota. cant remember what packaging the gasket had. give them an email, they are pretty good at getting back to you.
  4. Aug 5, 2022 at 10:31 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I'm about to install these headers too. Can't wait.
  5. Aug 5, 2022 at 7:13 PM
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    Does anyone in California have the LCE header even though its not CARB compliant? Doug Thorley headers are compliant but of course they are out of stock.
    Sorry for the highjack OP
  6. Aug 6, 2022 at 9:49 AM
    Doc76251
    Doc76251 Well-Known Member
    2016 ACLB
    I installed the LCE long tube header on my 2.7L about 2 mos ago and I have no issues. The header gasket looks the same as the original Toyota one.
    Cheers,
    Doc
  7. Sep 1, 2022 at 1:14 PM
    that_06regularcab
    that_06regularcab 3rd gear wide open in a Toyota
    Southern Oregon
    I have lce headers and gaskets solid no issues
  8. Sep 1, 2022 at 2:22 PM
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Hmmm…
    I tried reusing the OEM header to mid-pipe gasket on our 07 with less than 30k miles and it was a no go! Then used the suppled gasket and it worked. You can tell by looking the LCE gasket is not the same quality as the OEM gasket. Thanks that reminds me I’m having a totally new exhaust system built on the 7th. w/ 2.5”, 304 stainless, TIG butt welded, using a high flow cat, w/ two Magnaflow’s a 5x8x14 and a 5x11x22 to a hidden turn down at the right rear OEM step bumper.
    The supercharger w/ the header add a LOT of volume to the exhaust note!
  9. Sep 1, 2022 at 10:46 PM
    that_06regularcab
    Southern Oregon
    What supercharger you runnin? Urd?
