Could you...
Discussion in 'Off-Topic Discussion' started by 04LTtacoma, Apr 14, 2011.
  1. Apr 14, 2011 at 10:27 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Morty
    Outer Space
    push start a toyota tacoma with a 5-speed manual in it?
  2. Apr 14, 2011 at 10:28 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
  3. Apr 14, 2011 at 10:31 PM
    Unleashed
    Unleashed Member
    Brian
    North Hills, CA
    06 Prerunner
    General Graber at2 tires prerunner bar by fabtech 3inch leveling kit Hid Kit Kc slim lights Tinted tail lights Flat black Headlight housings
    Yes you can
  4. Apr 14, 2011 at 10:32 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    really zach? :rofl:
  5. Apr 14, 2011 at 10:34 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Probably not uphill.
  6. Apr 14, 2011 at 10:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    depends on how strong you are lol:eek:
  7. Apr 14, 2011 at 10:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    put it in reverse and do it down the hill :thumbsup:
  8. Apr 14, 2011 at 10:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    suing the internet is not possible:D
  9. Apr 14, 2011 at 10:49 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    :pout:
  10. Apr 14, 2011 at 10:55 PM
    chazjb
    chazjb Well-Known Member
    James
    Oregon
    Deck plate mod, Magnaflow exhaust, Toytec 3in lift, Bestop canopy, Spray on bedliner across the bottom foot of the truck and fenders. HID 6000k 85W converted Hella 500's & 4000's, HID headlights 5000k 35W. Custom build roof basket, Pioneer Avic-x920bt deck with rockford amp and kicker sub.
    Push the truck at a pretty quick pace. (Downhill is better because then its picks up its own momentum). Once its rolling push the clutch in, put the truck in 2nd and drop the clutch. The momentum of the tires/driveline will turn the motor over and voolah. Its called a bump start. done it many times.
    Hope this helps more than " yup"
  11. Apr 15, 2011 at 9:12 AM
    04LTtacoma
    Morty
    Outer Space
    I thought so I just wanted to make sure. lol I should give this a try some time!
    So basically if your in a automatic your screwed?
  12. Apr 15, 2011 at 9:20 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    you CAN do it in an auto but 1 it will probably do some damage and 2 you gotta be pushin atleast 40ish mph to get it to start
    so basically yes your screwed :D
  13. Apr 15, 2011 at 9:40 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    yes... i have had to do it a few times with my pre taco. :rolleyes:
  14. Apr 15, 2011 at 12:23 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Yes. On level or on a slight downgrade, you can.
    Put it in third gear, hold 3/4 throttle till started, pop clutch and quickly disenaguge. Should work on first try.
    Works on cars and motorcycles. 3rd gear greatly reduces the stress and scrubbing of the tires involved with a 1st gear bump start.
